Need some input.
11 replies to this topic
#1 medic25096 OFFLINE
medic25096
  • 13 Thanks
  • 5 posts
Posted February 01, 2016 - 05:00 PM
I have an bookend H16xt. I just did a rebuild on the engine and it seems to be running great! My tractor has side shields over all the fins in the heads and also has sides on the hood. I'm thinking about leaving them off so the engin can run cooler. I live in the south and all this tractor does is mowing. What's your opinion?
  • WrenchinOnIt said thank you
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,545 Thanks
  • 961 posts
Posted February 01, 2016 - 05:18 PM
Welcome
Good question because you certainly see it a lot.HOWEVER
Side tins on tractor ,up to you. SIDE TINS ON ENGINE ARE THERE TO ENSURE COOLING ! Mfg put them on for a reason, reason is to encompass air from flywheel and help capture it to cool the head(s)/cylinder(s). MOST DEFINITELY leave them on.
Edited by WrenchinOnIt, February 01, 2016 - 06:19 PM.
  • Bolens 1000, limebuzz, MH81 and 6 others have said thanks
#3 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 488 Thanks
  • 380 posts
Usually engine tins are there to direct air coming off the flywheel or fan over the engine to help in cooling, so you maybe shooting yourself in the foot by leaving them off.
  • KennyP, WrenchinOnIt, boyscout862 and 2 others have said thanks
#4 KennyP ONLINE
  • 37,399 Thanks
  • 45,453 posts
Posted February 01, 2016 - 06:16 PM
Welcome
Side tins on tractor ,up to you. SIDE TINS ON ENGINE ARE THERE TO ENSURE COOLING ! Mfg put them on for a reason, reason is to encompass air from flywheel and help capture it to cool the heads. MOST DEFINITELY leave them on.
I agree totally!
  • boyscout862, propane1 and medic25096 have said thanks
#5 Jack OFFLINE
Jack
  • 1,271 Thanks
  • 850 posts
Posted February 01, 2016 - 06:22 PM
Well I am Guessing your talking about leaving the hood sides off not the engine tins correct?   If so I wouldn't see a problem with that.
Welcome to the forum.   :wave:
#6 propane1 ONLINE
propane1
  • 8,430 Thanks
  • 4,027 posts
Leave tins on, also, if you can, or is there a way to check the timing. Late ignition timing will cause over heating. To far advanced may too, but I know , late timing will cause heat.
Just some thoughts.
Noel
Edited by propane1, February 01, 2016 - 06:24 PM.
  • limebuzz, Jack and medic25096 have said thanks
#7 Jimkemp OFFLINE
Jimkemp
  • 218 Thanks
  • 133 posts
Posted February 01, 2016 - 06:27 PM
Motor tins on and side covers off , only thing about the side covers off is the fan will pick up more grass and suck it into the motor , so just make sure you wash out the motor once in a while when its cool , :welcome:
  • MH81, boyscout862 and medic25096 have said thanks
#8 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted February 01, 2016 - 06:58 PM
:welcometogttalk: & :wewantpics: please.
  • boyscout862, karel and medic25096 have said thanks
#9 glgrumpy ONLINE
  • 8,549 Thanks
  • 7,877 posts
Posted February 02, 2016 - 07:50 AM
Many new tractors with plastic hoods say NOT to run it with hood open!  Top of hood might have big inlet screen, mine does and a boot all around engine shroud and air gets pulled into flywheel there better if hood is closed. So they say.  Even my newer Power Kings say to leave all the tins on for cooling flow and not to suck up grass clippings from the bottom. PIA to work on them, but should stay on for better cooling they say.
  • medic25096 said thank you
#10 medic25096 OFFLINE
medic25096
  • 13 Thanks
  • 5 posts
Posted February 02, 2016 - 02:59 PM
Thank you all for the info! I didn't think about the shields acting like a vent pulling airflow from the flywheel. I do however think I'll leave the side tins off. Oh and tom I added a few pictures! I'll add more when I get it all put back together and washed up!! It's a mess at the moment after a summer of mowing 8 acres!
#11 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted February 05, 2016 - 08:44 AM
:welcometogttalk:
#12 Paulgo OFFLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted February 05, 2016 - 10:35 PM
As has been said, the engine tins are for cooling. The hood side curtains were more for noise reduction, but also help direct cooling air.
Did you know there is a large Bolens section here?
http://gardentractor...-tractor-forum/
Paul
Edited by Paulgo, February 05, 2016 - 10:37 PM.
