1886 tiller on a 1455
30 replies to this topic
#1 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 06:40 PM
If i'm reading the attachment chart right a 33 inch tiller off a 1886 should work on a 1455..The only difference i can tell is i would need the shorter drive shaft..Hope someone can look at this for me and make sure i'm right..Thxs
#2 chieffan OFFLINE
  • 16599 Thanks
  • 9089 posts
Posted January 31, 2016 - 06:55 PM
Shortening a drive shaft is easy.  Making one longer is a little more work.  From what I read in the fitment table you should be good to go.
#3 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 07:07 PM
yea that's what i thought..Really excited about this..Just hope everything comes together..Hopefully The fella i'm buying the tractor off of still has it..Also hoping me and oddfirecj2 can work something out..Never owned a garden tractor before and i'm kind of pumped right now..lol
#4 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted January 31, 2016 - 07:40 PM
If it is a 33" Model 18090 tiller, you need the shorter driveshaft. If it a 33" Model 18093 tiller, you need to change both arms on the tiller and the driveshaft. With that said, the tiller will fit.
  • WrenchinOnIt said thank you
#5 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 08:22 PM
Yes..But looking at the chart the 18090 and 18093 used the same arms..So if i'm reading it right 1455 should use the same arms as a 1886 if it is a 18093..If that makes sense..lol
#6 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 08:52 PM
Okay..Looking at this a little more..If this is a 18093 i will need the 1718301 R.H arm and the 1718304 L H arm..So i need to make sure if this is a 18093 tiller it has these arms..Correct?
#7 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted January 31, 2016 - 09:02 PM
Correct. The arms can be changed out though if it does not have the correct arms for your application.
#8 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 09:07 PM
But where would one find these arm if i need them..I'm assuming that would be about impossible..
#9 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted January 31, 2016 - 09:28 PM
The arms might not be easy to find, but others have found them, and some of the Bolens parts suppliers on here have been very helpful with this in the past.
#10 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 31, 2016 - 09:43 PM
If you mean the mount arm on the tiller those don't need to be changed for the tiller to fit on a 1455.
#11 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 31, 2016 - 09:53 PM
If you need arms let me know,I believe I have a set here,just pm me
Edited by blackjackjakexxix, January 31, 2016 - 09:57 PM.
#12 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 10:21 PM
Okay folks..The tiller i'm looking at belongs to oddfirecj5..Just don't buy this tiller until i get this sorted out..lol..Go to the Buy/ sell..He has pictures of the tiller..It's look's like lift arms are there..This looks like a 18090 to me..There's nothing else that need's to be on tractor for this tiller to mount  are they.. Where can one get a diagram showing how this is mounted..Thxs to all who has helped me..
#13 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 31, 2016 - 10:34 PM
That tiller will work on your tractor you just need a shorter drive shaft.
#14 lugnuts OFFLINE
lugnuts
  • 1 Thanks
  • 18 posts
Posted January 31, 2016 - 10:42 PM
I was pretty sure it would..Thxs..Just wanted to make sure..One more question and i'll quit bugging everyone..Do they make a diagram of how this mount's to tractor..Like i said i have never owed a Bolens before and want to do everything right..I've search on here but might be overlooking it..
#15 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 31, 2016 - 10:57 PM
Its simple the arms on the tiller have have a slot on the ends those slide over the lower pins on the ears on the rear end of the tractor.  Make sure you put the top pins in the ears on the rear end or the tiller will hop off.  Then the two lift arm hook to the rock shaft under the tractor with two pins.  Slide the drive shaft on the tiller and pto, lock it and your good to go.
