* * * * * 2 votes
Brother of Hulk II
489 replies to this topic
#76 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 16, 2016 - 08:50 PM
I power washed a bunch of frame parts, and split the frame in prep for sanding and paint. Went to pick up the paint and they were out of Gloss Black, but I was able to pick up 10 cans of Grey. I guessitamate it will take close to 16 cans of Grey and 10 cans of black, 2 cans of silver, and 1 can of black hi-temp.
  • wvbuzzmaster said thank you
#77 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 18, 2016 - 08:55 PM
Quick update, I was able to get the transaxle to shift into Lo Range, and I filled the holes in the dash that the PO made. Still waiting on a shipment of Black paint.
Edited by larrybl, February 18, 2016 - 08:56 PM.
  • wvbuzzmaster, KennyP and EricR have said thanks
#78 EricR OFFLINE
EricR
  • 716 Thanks
  • 428 posts
Posted February 18, 2016 - 09:05 PM
You are doing a great job so far Mr Larry, but please refrain from telling us you are mowing grass, LOL!!!!
  • larrybl, KennyP and dodge trucker have said thanks
#79 shorty ONLINE
shorty
  • 5,915 Thanks
  • 5,450 posts
Posted February 18, 2016 - 09:31 PM
When our temps are in the teens and Larry is busy mowing... Makes me jealous cause I am ready for spring time.
  • larrybl and dodge trucker have said thanks
#80 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 18, 2016 - 09:36 PM
Well I hope to get some more power washing done Saturday, and it looks to be too wet to mow Sunday. Hope that makes you feel better. :poke: Notice that I am not the only one that thinks 60's in February is considered "Cool".
Edited by larrybl, February 18, 2016 - 09:39 PM.
  • MH81, Alc, KennyP and 2 others have said thanks
#81 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 20, 2016 - 09:55 PM
Long day here, I power washed more parts and the transaxle. I ran into an issue with the fan screen screws, I drilled the heads off so to remove the booster fan, I'll drill it out using the bench drill press. The booster fan is NLA, and made of brittle aluminum. Slow and steady as she goes.
#82 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 20, 2016 - 09:57 PM
We went to a new place they opened here called Urban Air. Acres of trambolenes, Climbing areas, Dodge ball, and Ninja Warrior obstacle course. I got tired just watching. He had fun!
#83 MH81 OFFLINE
  • 29,979 Thanks
Posted February 20, 2016 - 10:57 PM
Might see if wvbuzzmaster has one
  • larrybl said thank you
#84 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 20, 2016 - 11:09 PM
The fan booster is fine, I just have to carefully drill the screws out, I had to do this on one other. It is easier to use the drill press, that is why I drilled the screw heads off to remove the fan.
#85 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 21, 2016 - 12:53 AM
More engine teardown, I need to find my 1-1/4 socket tomorrow. The starter gear and magneto looks good, they were confirmed working properly with the initial start-up. Depending on parts availability I might go into the block and have it specked. I'll go on to Searspartsdirect tomorrow to build a shopping cart.
I need these.
Gasket kit
Breather Tube
Front wheel seal caps
Spindle top seal caps
and some other things
#86 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 21, 2016 - 02:17 PM
Spent some time on Sears Parts this morning building a cart. I am at $114.00 minus shipping. Just trying to make sure I have everything I need, to open the block and check the internals. I'll need to build some funds up before I place the order, anyone think of anything else I should add?
1 ea. 495868 Gasket kit $59.33
1 ea. 691897 Breather Tube $14.10
1 ea. 121433X Amp Gauge $6.74
3 ea. 104757X Wheel hub caps $3.00 each. Red needs one also.
3 ea. 121232X Spindle caps $3.94 each. Red needs one also.
2 ea. 7393R Axle seals $3.00 each. With 3 transaxles I figure good to have on hand.
1 ea. 110542X Shifter boot $3.25, Not sure needed, but just in case.
Belts, Tires, bushings, bolts, and other items will be searched locally.
#87 MH81 OFFLINE
  • 29,979 Thanks
Posted February 21, 2016 - 04:46 PM
Steering bushings?
#88 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted February 21, 2016 - 05:12 PM
Steering bushings?
I looked, NLA. I'll look local for the brass bushings, and I have successfully used flashing tin for the thin nylon bushings.
I was expecting a fight here, pulling the flywheel. I found my 1-1/4 socket and removed the bolt, then threaded it back on 1ith a 1/2" clearance. Got out my HF "bent" puller and installed it. Three squeezes on the impact trigger and wala! popped right off.
  • MH81, wvbuzzmaster and KennyP have said thanks
#89 KennyP ONLINE
  • 41,448 Thanks
  • 47,379 posts
Posted February 21, 2016 - 05:44 PM
I have the same puller set. Has done well for me.
#90 UncleWillie OFFLINE
  • 16,402 Thanks
  • 9,025 posts
Posted February 21, 2016 - 08:53 PM
Hey give my impact back. I have been looking for it!
  • larrybl and wvbuzzmaster have said thanks
