I guess I am officially done on BOH, except for the show later on. Will be clearing the bench's and putting tools and left over parts away this weekend in prep to start on "Little John"
Brother of Hulk II
#437
OFFLINE
Posted July 08, 2016 - 08:23 PM
PS, Only took a little over 7 Months this time.... But I didn't tear the engine all the way down.
- MH81 said thank you
#438
ONLINE
Posted July 08, 2016 - 09:58 PM
jhn9840
John
- larrybl said thank you
#439
OFFLINE
Posted July 09, 2016 - 04:11 AM
Looks real good, Larry.
#440
OFFLINE
Posted July 09, 2016 - 06:09 AM
I started back thru and decided to just ask...
Did you fill the tires?
Might be a good idea to do so if you're going to use that back blade any.
#441
OFFLINE
Posted July 09, 2016 - 09:46 AM
Larry,
No, I didn't fill the tires. When I use the blade it goes on Hulk II with the rear Ag tires. It does real well on him. BOH is just for show "for now". https://www.youtube....h?v=-m15uemFXHE I am actually mowing this area now.
- MH81 and Potsie33 have said thanks
#442
OFFLINE
#443
OFFLINE
#444
OFFLINE
Posted July 20, 2016 - 02:58 PM
Better than any tv show I would be able to find. Thanks for the great entertainment. Good lookin' GT's
- larrybl and jpackard56 have said thanks
#445
OFFLINE
Posted July 26, 2016 - 07:17 PM
The Second canopy came in today. Now for the $69.00 question. I will have to modify this to make it fit. Consists on drilling the mounting holes in the brackets larger to fit my spring bolt studs. The way it is supposed to go is with bolts down through the springs. Mine have the studs that come up. Should I modify it, or give up on the canopy for this?
#446
OFFLINE
Posted July 26, 2016 - 09:49 PM
What the heck, it's only $69.00. I drilled the holes and ran into another snag. I had to put the mounts through the bottom of the seat springs, little challenge to get the spring nut started. I had to locate two 1-1/2 bolts for the front seat bracket, the kit had the correct bushings for the front seat pivot. Once the bottom bracket was tightened up it feels pretty stiff and makes a good grab bar. This is also the transport mode, Only 2 wing nuts hold the canopy on. I wish the canvas was Grey, Do I have any options there?
- KennyP said thank you
#447
OFFLINE
Posted July 26, 2016 - 09:57 PM
Make sure it's a dye that has a colorfast process. Natural fibers are easier. Salt water and vinegar will often do it.
Just double check.
Girl in HS dyed her shoes for prom... It rained... She had purple feet for a long time.
- larrybl and KennyP have said thanks
#448
OFFLINE
Posted July 26, 2016 - 10:08 PM
The manual says "Vinyl Canopy". Feels like canvas to me.
#449
OFFLINE
Posted July 27, 2016 - 06:19 AM
Good looking canopy, Larry!
