* * * * * 2 votes
Brother of Hulk II
489 replies to this topic
#286 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 22, 2016 - 07:44 PM
Why positive ground?
These have the dual diode regulator. The + side goes to the ignition switch for battery charging and PTO operation. The - side goes to the lights. So this makes the lights DC but at a positive ground.
Edited by larrybl, May 23, 2016 - 08:00 AM.
#287 MH81 OFFLINE
  • 29,979 Thanks
Posted May 22, 2016 - 10:12 PM
Well, that would make it so you have to pay close attention if you decided to put in LED headlights
  • larrybl said thank you
#288 TAHOE OFFLINE
TAHOE
  • 8,333 Thanks
  • 5,815 posts
Posted May 23, 2016 - 06:57 AM
For those that have sleeve hitches, this is probably the most used attachment I have. (I do have a 38" blade also).
I made a 1-7/8 ball hitch attachment for my little 4X5 trailer and use it constantly with Hulk II. Even makes unloading the trailer easier allowing to tip it slightly. I have a larger trailer 6X8 now and I needed a 2" ball. For now only Old Girl can move it as I installed a 2" receiver on her. I wanted a 2" ball attachment that I can use on Hulk II and BOH's sleeve hitch.
Tractor supply has a pin that fits in the sleeve hitch, but you need to grind a lip off so it sets lower allowing the pin to be inserted under Neath.
Then you need a 2" ball and cut the threaded shaft off (expect to use 2-3 hacksaw blades in your saws all).
Next, have the neighbor weld the two parts together. He will do this for me tomorrow.
I'll now have a 1-7/8 and 2" sleeve hitch ball. :rocker2:
I'm doing the same thing, found an old 1 7/8 ball with screwed up threads in my tool drawer. I will use it for both  1 7/8 and 2" trailers so I will only need one.
  • larrybl and MH81 have said thanks
#289 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 23, 2016 - 08:03 AM
Yes, that is why I had a hard time finding LED's that had both red & black wires. I will test them once I get the engine running before I drill holes in the fender pan.
#290 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 23, 2016 - 08:06 AM
I didn't think you could use a 1-7/8 with a 2" trailer. I guess just for moving it around, but I will have a load on mine so I am making a proper 2" for it. Thanks.
#291 TAHOE OFFLINE
TAHOE
  • 8,333 Thanks
  • 5,815 posts
Posted May 23, 2016 - 11:02 AM
My buddy pulled his 14" landscape trailer with a 2" coupler using a 1 7/8" ball for years. I couldn't believe he did it, but it never came off.
Yes, I just move the trailers around the property, never on the road, works fine
#292 UncleWillie OFFLINE
  • 16,402 Thanks
  • 9,025 posts
Posted May 23, 2016 - 12:05 PM
If you jar it hard enough a 2 inch will jump off a 1 7/8 ball. Otherwise it isnt much problem. Not really safe on the road though.
Edited by UncleWillie, May 23, 2016 - 12:06 PM.
  • larrybl and TAHOE have said thanks
#293 bbuckler OFFLINE
bbuckler
  • 3,800 Thanks
  • 3,307 posts
Posted May 23, 2016 - 01:14 PM
One of the worse wrecks my dad ever towed was someone was towing a trailer full of tobacco and it got loose going up hill and ran over a car. The people behind did not survive.
#294 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 23, 2016 - 07:27 PM
@#$^@ Sears Parts Direct!!!!! :mad2:  :mad2:  :mad2: . I got the PTO switch, in a baggie and no nut! WTH!!!! Who sells a switch without the nut! and it is an odd ball nut too-boot! 1mm pitch. I dug through all my part boxes and found several 1mm pitch but not big enough. Hope I'll find one at work tomorrow.
#295 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 23, 2016 - 09:33 PM
Grandson commandeered the computer which allowed a second search of the shop for a nut, Nothing turned up till I thought (wait a minuet) the GT came with a PTO switch. So I went through the parts bags and there it was :wallbanging: . Under dash wiring is done so now I can install the fire wall. Oh I was so pissed at Sears that I forgot I had this in the trunk of the car.
  • MH81, KennyP and TAHOE have said thanks
#296 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 25, 2016 - 09:22 PM
A BOH update. Regular Work takes presentence, but for the last couple evenings I labeled the shifter plates (I think this looks good). Installed the fire wall and fuel lines. I need to pick up a filter to complete the fuel lines and add gas. Dressed out the electrical and picked up a 360 CA battery and tie down. Had an issue with the throttle cable, it is too tight. It will allow WOT but on return to idle it wouldn't retract fully, so I am trying to let oil seep into it over night. I also relocated the jack stands so when I get him running I can go through all the gears.
I think I am still on track to have a running video this weekend.
Edited by larrybl, May 25, 2016 - 09:25 PM.
  • MH81, KennyP and TexasG have said thanks
#297 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 25, 2016 - 09:57 PM
My view if I turn my chair around.
#298 UncleWillie OFFLINE
  • 16,402 Thanks
  • 9,025 posts
Posted May 26, 2016 - 06:17 AM
The guy who packaged that switch must havebeen the same guy who packaged the brake adjuster hardware on the Dakota.
The lettering looks ok. Different though.
#299 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 26, 2016 - 08:59 PM
Well I promised a video, but I picked up a fuel filter and installed it. Put about a gallon of has in the tank (no leaks) and pulled the line off the carb and sucked on it till I saw gas in the new filter and re-attached the line. Camera battery was dead so I thought I would just test it once. Woo Hoo it fired right up. Milestone met. I'll get a video once the camera is charged.
#300 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 27, 2016 - 08:20 PM
The promised video, I did cheat and primed the carb, but ran into an issue with the drive belt. I loosened the idler as far as it would go and the brake would not stop the belt allowing gear changes. I put the old belt (both are specified as 1/2 X 98") but after examining both belts the Husky is slightly larger in width. I think I need to order two OEM 110883X from Sears. The PTO and seat safety worked perfect. Stay tuned for a LED Headlight POSSIBLE update (still in the R&D phase).
https://www.youtube....eature=youtu.be
  • KennyP and UncleWillie have said thanks
