* * * * * 2 votes
Brother of Hulk II
489 replies to this topic
#16 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 01, 2016 - 07:39 PM
Son wouldn't have worked, I think they are the same age. Anyone want and try to decipher the S/N for a built on date?
#17 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 01, 2016 - 07:48 PM
Resembles mine...917.255919
Hulk II is a 917.255919. I will look close for differences, so far I haven't found any.
#18 jhn9840 ONLINE
jhn9840
  • 339 Thanks
  • 337 posts
Posted February 01, 2016 - 08:29 PM
If you go over to that other tractor forum and put your model number into the search function there is a thread that pops up from 7/15/2009. I didn't read the whole thing but those guys seem to be in agreement its a1988. I'd post up the link but never have had any luck doing that from this I Pad.
jhn9840
John
  • larrybl said thank you
#19 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 01, 2016 - 08:50 PM
Thanks, I'll check that out. I was pretty sure he was a 88 vintage.
#20 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 01, 2016 - 09:06 PM
Looks like I found the first difference.
917.255919 (Hulk II) doesn't have a drive belt adjustment pulley (could be added)
917.255914 (Brother) has an adjustment.
#21 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 01, 2016 - 09:33 PM
Messing around with him tonight. Main plan was to check the electrical, so no "gas" yet. Installed a battery and removed the drive belt. Checked all the safeties, the one under the seat is fubared. No action with the key switch. I jumped the solenoid with a booster cable clamp and it cranked. I then used a jumper from the battery + to the white solenoid wire and he cranked. So far so good. Starter sounds strong, and no un-usual clanking noises from the engine.
https://www.youtube....eature=youtu.be
#22 MH81 OFFLINE
Posted February 01, 2016 - 10:55 PM
Glad things are going your way.
#23 JDub OFFLINE
JDub
  • 54 Thanks
  • 43 posts
Posted February 01, 2016 - 11:32 PM
Looking forward to tracking your progress. Your very admirable work helped inspire me to dive into this hobby.
#24 EricFromPa ONLINE
EricFromPa
  • 3,512 Thanks
  • 3,064 posts
Posted February 01, 2016 - 11:58 PM
Looks like she's sat in someones barn for a while.I would pull the heads and do some carbon cleaning.And bypass the fuel pump for the time being.We know that's gona be bad. :rolling:
I've never had one that sat have a usable fuel pump.Either rebuild the pump or replace it.And change the Oil no matter how clean it looks.
  • larrybl and jpackard56 have said thanks
#25 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 02, 2016 - 09:05 AM
Yes to all the above. I just want to hear it run for a minuet or two before I tear it completely down. I should be able to fire it up this evening.
#26 bbuckler ONLINE
bbuckler
  • 3,292 Thanks
  • 2,969 posts
Posted February 02, 2016 - 01:12 PM
To bad you didn't know about the keyswitch while you where here. I probably have one in my part bin.
Edited by bbuckler, February 02, 2016 - 01:13 PM.
#27 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 02, 2016 - 07:28 PM
Thanks Brandon, I have several too, I just didn't want to jack with the electrical as it will all be re-built. I may need a fuel pump, but this one started puking what gas was left in it after I by-passed it, so it may only need rebuilt. I may just de-carbon this as it sounded really good. I think the engine was maintained some what as it was full of clean oil (which will be changed).
https://www.youtube....h?v=JdNfKKif2qc
  • bbuckler said thank you
#28 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted February 02, 2016 - 08:05 PM
Larry,  That has a B&S motor?  You could estimate the age from the code on the motor.
#29 UncleWillie OFFLINE
  • 15,514 Thanks
  • 8,701 posts
Posted February 02, 2016 - 08:13 PM
Sounded pretty good on the video.
#30 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,843 Thanks
  • 4,344 posts
Posted February 02, 2016 - 08:33 PM
I think 05/1988 is what I see
  • motobreeder said thank you
