Where do you get the material at ? My SS15 has no brake right now.
Post 137
Edited by larrybl, March 26, 2016 - 07:03 PM.
Posted March 26, 2016 - 07:03 PM
Post 137
Posted March 26, 2016 - 09:08 PM
Transaxle is done. I went with the High-Strength lining 6224K341. It has a lot of metal in it, It bonded fine, buy you need to zip tie the band so to be close to the final shape needed. I filled with 5 qts 30W Non-detergent. Everything spins fine. Next up is the frame.
Posted March 28, 2016 - 08:44 PM
Experimented with removing the old decals (in one piece). Used a heat gun and razor on a small one with good success. I am out of "Goop off" so I tried carb cleaner to remove the glue, it came off like black tar. I hope to get one of the large decals off in one piece so later I might find someone that can reproduce them. I can create the shift decal but will need a good picture of one to go by.
Posted April 01, 2016 - 06:28 PM
Got the old decals removed, and have been prepping the frame rails for paint. Been too wet and humid for painting, hopefully get these parts done tomorrow. I have a trip planned to Ennis TX Sunday to pick up some parts machines with some (hopefully) parts I can use.
Posted April 01, 2016 - 06:38 PM
You going to see matt (98murray)
Posted April 01, 2016 - 07:14 PM
Yep, He asked how much I could haul
Posted April 01, 2016 - 07:25 PM
46 is what he was up to the last post I saw
Posted April 01, 2016 - 07:38 PM
What kind of carb are you needing? I can see if he has one.
Posted April 01, 2016 - 08:00 PM
I'm for sure he doesn't have one. Matt more into LTs and most 80s and up.
Posted April 02, 2016 - 07:58 PM
A couple more restores and it will be all painted.
Posted April 02, 2016 - 09:50 PM
I'll let the paint harden some more before I start adding items. Shop door is open to clear the paint smell. Still going to Ennis in the morning. Oh, and RED did good, got 1/2 the yard cut, no knocking after I changed the oil.
Posted April 03, 2016 - 07:31 PM
Thanks to Matt (98 Murray) I have acquired several parts that will be useful on BOH, Hulk II, and RED! About a 6 hour round trip, and took a full tank in the Ranger to get there and back. It was an enjoyable trip. Once I got home I had to finish mowing the yard, and the Wife has decided to clean out the other shop so I need to move the rest of my stuff (junk to her). I used Hulk II and the abused trailer to move my "junk". Then I needed to move the booty from Ennis TX (Thanks Matt) from the drive out to my shop. Old Girl worked a treat under load. With the 2" receiver I installed on her I almost wanted to drive further with the loaded trailer. Got everything to the shop, taking a break and watching the Simpsons before I unload Hulk II. I scored a 42" deck mainly for mandrills and pulley parts, A Briggs 18 Opposed Vertical for a Spare for RED, Dash with the metal plate insert, A complete sleeve hitch (will work good on BOH) and the metal steering bracket for Hulk II. A couple transaxles, and steering parts.
Posted April 03, 2016 - 11:18 PM
Hey you got a bug eye. You have to fix it up.
Posted April 04, 2016 - 06:17 AM
Sounds like a good score on parts. I am going to have to go to work on the Craftsman (III) GT20 for Steve! The plowing bug has bit him good!
