* * * * * 2 votes
Brother of Hulk II
489 replies to this topic
#136 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 20, 2016 - 10:48 AM
I'll get to RED this afternoon, kinda chilly here in Texas this morning, Have the heater going in the shop. Paint is dry and the engine is finished. I'll finish setting the air gap and break out my 10 amp power supply to test it out.
  • wvbuzzmaster said thank you
#137 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 20, 2016 - 04:58 PM
I looked for the Part # for the brake lining that I had ordered before. I think it went with BMP's book when I sold him. I think I located what I need at http://www.mcmaster....lining/=11mjf5t Part # 6224K341, Metal free High Strength 1" X 3/16 strip. I'll order 2 feet, and keep some on hand.
This is as far as I'll go on the teardown of the transaxle. Very slight seepage on the left seal, not enough to warrant replacing it. Clean up under the shifter boot, some rust under there that is making it stiff. I pulled the Hi-Low pin and emery clothed and oiled it, shifts fine now. Deciding on the color scheme for it.
#138 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 20, 2016 - 05:16 PM
Still thinking on what I want to do. I have done Black/Silver on the Roper, and Silver/Black on Hulk II. I'll probably do something with the Grey, but I think I like the Black/Silver better.
  • Sawdust said thank you
#139 MH81 OFFLINE
  • 29,979 Thanks
Posted March 21, 2016 - 04:13 PM
I like the black with silver accents.
You could intro another color... Say Red?
  • larrybl said thank you
#140 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 21, 2016 - 04:33 PM
The theme on BOH is grey, I may substitute that sor the silver.
#141 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted March 21, 2016 - 05:22 PM
A dark Red will go with Gray well!
#142 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 21, 2016 - 09:06 PM
Red is not speaking to me. Black, Grey, and Pulleys in silver. Being under the tractor this should work. I did manage to pop both drive and brake pulleys off, and some dremel detail. Contemplating changing the one questionable seal. Not sure of the best way to remove the old one. Usually use a small flat tip and hammer it into each side of the seal and pry it out staying away from the seal seats. May need to order a few more seals. But as I said the seepage doesn't seem bad enough to warrant doing this. Another option would be to add some of the voodoo seal restorer when I put new oil in. Building funds for the brake band and paint.
OOps, forgot pictures.
Edited by larrybl, March 21, 2016 - 09:11 PM.
#143 MH81 OFFLINE
  • 29,979 Thanks
Posted March 22, 2016 - 04:47 PM
I usually use a sheet metal screw and a slide hammer if they are junk.
#144 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 22, 2016 - 06:18 PM
Well, it was full of oil when I got it so not leaking enough to change.
#145 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 23, 2016 - 07:10 PM
It is nice to have something to take my mind off "Life". Too much pain and death going on lately around me. Progress on the Transaxle, Almost ready to paint. Brake band material has been ordered, I got 3' coming as I use this stuff often.
#146 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 25, 2016 - 09:49 PM
Not much to report, Thought some would be interested in the little valve that allows you to add oil without burping, and how I attach brake band material.
#147 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted March 26, 2016 - 04:40 AM
Neat little valve! Where did you get it? Like your clamps for the band too!
#148 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,649 Thanks
  • 4,639 posts
Posted March 26, 2016 - 12:29 PM
It is factory, I assume it comes on all the 145401X peerless.
#149 bbuckler ONLINE
bbuckler
  • 3,803 Thanks
  • 3,307 posts
Posted March 26, 2016 - 02:49 PM
Where do you get the material at ? My SS15 has no brake right now.
#150 UncleWillie ONLINE
  • 16,405 Thanks
  • 9,026 posts
Posted March 26, 2016 - 04:17 PM
Hope you don't need a jump start before that sets up.
