140 h3 hydraulic levers removal ? One broken.
2 replies to this topic
#1 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted January 31, 2016 - 01:10 PM
Anybody know how to get the levers out of the tractor. No information in service book. I think mine broke where the lever hooks to the shaft going thru tractor side, into the valve.
Thanks for any helpful advise.
Noel
#2 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted January 31, 2016 - 03:11 PM
First remove battery and tray. Next you will need to remove the pins that hold the arms from the valve to the handles. Next there is a set screw on the outside arm once removed you should be able to pry the bracket off the handle and remove there is also a small woodruff key so be careful not to lose. Once that is off the rest will slide out
  • Texas Deere and Horse and propane1 have said thanks
#3 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 01, 2016 - 11:39 AM
Thanks for your help, it's nice to know what your up against, before getting into it. Handle is repaired now, and will be going back together in a few minutes.
Noel
  • Texas Deere and Horse and Trav1s have said thanks
