Tractor Build
32 replies to this topic
#31 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted May 02, 2016 - 06:52 AM
Shane
Edited by holdenboy1960, May 02, 2016 - 06:53 AM.
  • KennyP and MolonLabe have said thanks
#32 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted June 29, 2016 - 12:22 AM
Little UPDATE
found a couple hrs the last 2 nights so put the time to use
swapped out the front tires & rims from the quad style to a smaller wheels & tires 4.80 x 4 x8 ,
4 ply PB090005.JPG and i have an option to go a larger tires if i want too ,
 PB090007.JPG 7.5 x 4 x 8 , 4 ply as shown in the 2nd pic , but i like the small 1's .
They keep the front chassis a touch lower than the rear chassis line to help prevent wheel stand & such
 Have also finished removing  the belt clutch & fitting  the press pad clutch which makes a lot better &
tidier system & smoother too i have found
The rear tyres were bleeding out & got bored pumping them every day or 2 so fitted cubes in them
So i'm slowly getting it done , it should have been done 3 months ago,but ohhh well i'll get it eventually  ,will get a pic of the clutch when i can
Shane
  • Alc, KennyP, MFDAC and 1 other said thanks
#33 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted August 12, 2016 - 10:37 PM
Update ;
this is a pic of how the lift arms & gear was set up post-62113-0-97767300-1456502003_thumb.j
& this is how i got it set now , done away with the cross chains & replaced the little adjustable drop arms , the R/H side drop are i have to weld a pin on it so as to wind it for adjusting yet 20160812_150849.jpg
Have to make a top linkage yet too but getting there slowly , i had to re glue the pad to 1 side of the clutch so it would disengage to change gears 20160812_150920.jpg
as the pad was moving & grabbing on both clutch sections, 3 drops of super glue worked just fine for it
  • Alc, KennyP and MFDAC have said thanks
