Brinly 10 inch Plow Conversion to 3-Point Hitch
brinly 10 plow brinly pp-500 plow brinly 3-point plow brinly plow converting a sleeve hitch plo
61 replies to this topic
#31 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted April 07, 2016 - 04:04 PM
Got any pics? I did mine this way so I could trade between the 12" & 10" rather easily!
  • wvbuzzmaster and holdenboy1960 have said thanks
#32 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted April 07, 2016 - 04:30 PM
This was the only plow I used in Kentucky and it worked as planned. I am real happy with this!
  • wvbuzzmaster and TomLGT195 have said thanks
#33 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 07, 2016 - 05:17 PM
Ehem lol. I do believe there was another plow you used in Kentucky. Of course I too used both my plow and the 10" conversion plow. Both work great.
#34 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 30, 2016 - 08:09 AM
OK Tom LOL
that plowing was nice to watch ,thank you
  • CRFarnsworth and MNGB have said thanks
#35 MNGB OFFLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted April 30, 2016 - 12:12 PM
Hi thanks for posting you got it set up good just need to shine up the plow some but your getting the job done. I suppose for you this is fall plowing?
#36 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted May 01, 2016 - 07:41 AM
Hi thanks for posting you got it up good just need to shine up the plow some but your getting the job done. I suppose for you this is fall plowing?
That was fall plowing, and it really works good, as for shining up a plow.... Never .. The ground will do it just fine, It just takes a little extra power first few passes, then its all shined up and slick as a whistle.
  • limebuzz and MNGB have said thanks
#37 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 19, 2016 - 02:37 PM
I found some metal to make a 3-point hitch for this plow. Then it will have it's own and not share with the 12" plow. Got the pieces cut & bent today. I plan to tack weld parts together so the holes remained aligned. Here's some pics. Probably no more until next week due to the show.
I have some 2X2 square tube for the cross piece. I'm using the plans I drew up.
  • olcowhand, TomLGT195 and MNGB have said thanks
#38 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,721 Thanks
  • 971 posts
Posted October 19, 2016 - 07:28 PM
Looks great as usual, Kenny! What do you do your bends with? If you looked at my sleeve hitch at Daniels plow day, you know I'm in dire need of better techniques!
#39 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 20, 2016 - 04:16 AM
I used the 20 ton press with this on it.
  • Alc and SupplySergeant have said thanks
#40 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted October 20, 2016 - 04:36 AM
Kenny did you need to add heat along with the press or a cold bend ?
#41 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 20, 2016 - 05:25 AM
I did it cold, Al. If this was for a 12" plow, I would use 1/2" strap instead of the 3/8" I'm using for this 10" plow. That would probably need heat to bend.
#42 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,721 Thanks
  • 971 posts
Posted October 20, 2016 - 07:25 AM
Oddly enough, I just got a Harbor Freight 20-ton press! I have the blade from a large press brake, I'll build a lower die and guides to go with it. Thanks!
  • MNGB said thank you
#43 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 20, 2016 - 07:52 AM
Just be careful, the metal this press is built from is not good old USA metal!
  • Alc, SupplySergeant and MNGB have said thanks
#44 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,721 Thanks
  • 971 posts
Posted October 20, 2016 - 09:33 AM
I've noticed it seems a bit thin in places. I'll be careful!
#45 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 27, 2016 - 03:38 PM
Got some time today and fired up the welder. Had to drill some holes first. I tacked matching parts together to drill so holes would align well.
Trimmed the corners to make it look nice.
I had to 'extend' the 2X2 some.
All done and ready for paint!
  • olcowhand, limebuzz, TomLGT195 and 1 other said thanks
