Brinly 10 inch Plow Conversion to 3-Point Hitch
brinly 10 plow brinly pp-500 plow brinly 3-point plow brinly plow converting a sleeve hitch plo
61 replies to this topic
#16 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted January 31, 2016 - 06:32 PM
Hi I've thought about using a horse plow and converting it to 3 pt, how is yours working out, do you have any photos of it?
Thanks
Mine works excellent.I have pics of it before making and installing the wheel.As you can see I've made it so that the pins can be moved up or down to change the angle etc: I have it set up so that both pins can be at the same height but the angle of the plough mounted to the main frame is tilted to allow the wheel drop into the furrow.Sorry about no pics of the wheel.If I find them I'll post them.
Kenny sorry to high jack your post.
  • olcowhand, DH1, limebuzz and 4 others have said thanks
#17 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted January 31, 2016 - 06:41 PM
No problem on my end! Cool plow! You need the left side 3.5" higher for the correct angle.
  • limebuzz, holdenboy1960 and MNGB have said thanks
#18 MNGB ONLINE
MNGB
  • 2,627 Thanks
  • 1,570 posts
Posted January 31, 2016 - 06:55 PM
Thank you very much for the reply and photos I like it, it looks good, now if I could just find a plow in good condition and thank you Kenny.
  • KennyP and holdenboy1960 have said thanks
#19 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted January 31, 2016 - 09:10 PM
I'm following along closely Kenny, been wanting to convert my sleave hitch plow over to 3pt for a few years now.I made an A-frame to mount the plow to now,but it's not the greatest looking set up.
#20 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted February 01, 2016 - 05:59 AM
I have a drawing of the 'mast' in the manuals section here.
  • limebuzz and MNGB have said thanks
#21 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted February 01, 2016 - 06:33 AM
I like the looks of them ploughs, but I must say, my sleeve hitch plow seems to work very very good, I actually like it better than the 3 point one I have. Much easier to hook up, no fussing with the arms or offset, just drop the pin, tighten up the 2 bolts against the plow hitch and go plowing. Mine buries itself with ease and makes really nice furrows.
  • limebuzz, KennyP, TomLGT195 and 2 others have said thanks
#22 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted February 01, 2016 - 06:38 AM
You have your's set right then for your ground. Plowing different types of ground takes a bit to get them set right. Using a sleeve adapter on a 3-point puts the plow further back, thus a different set up.
  • limebuzz, Alc and MNGB have said thanks
#23 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted February 01, 2016 - 08:01 AM
This is true Kenny, that's why I made up a sleeve hitch to go on the tractor. Not an adpter, it was just as easy to remove the lower arms and stick on the sleeve hitch. I use the rockershaft arms to raise and lower the sleeve hitch via chains. Lets the sleeve hitch float fully so I never loose traction.
  • MH81, Alc, KennyP and 2 others have said thanks
#24 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted February 01, 2016 - 08:39 AM
At the moment I don't have metal to make a sleeve hitch. Plus most of the implements I build are for 3-point.
#25 TomLGT195 OFFLINE
TomLGT195
  • 4,054 Thanks
  • 2,901 posts
Posted February 01, 2016 - 04:19 PM
:camera: please
#26 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted February 01, 2016 - 05:31 PM
OK Tom LOL
Edited by skyrydr2, February 01, 2016 - 05:32 PM.
  • Alc, jpackard56, TomLGT195 and 1 other said thanks
#27 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted February 04, 2016 - 06:26 PM
This is on hold due to work getting in the way! At least the paint will be dry when I get back to it!
  • olcowhand said thank you
#28 TomLGT195 OFFLINE
TomLGT195
  • 4,054 Thanks
  • 2,901 posts
Posted February 05, 2016 - 02:23 PM
 no worries  :reading_the_manual:
:smilewink:
#29 KennyP ONLINE
  • 40,953 Thanks
  • 47,135 posts
Posted February 07, 2016 - 06:02 PM
I put the plow back together today. No pics, too much going on. I want to get this set up for Spring. May bring the trailer up and hang the plow off the back to get it close!
  • limebuzz, TomLGT195 and holdenboy1960 have said thanks
#30 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted April 07, 2016 - 02:02 PM
I have done a few of these conversions and I have found the Omni draw bar top link hitch attachment to be the heaviest and well made of all the similar ones and at a very fair cost . It works perfect for these type of situations and all you need to do is strip off the un-needed stuff from the Brinley and using some form of clamps or welding if you choose , attach the plow to the provided draw bar accessories holes . You can use the wider draw bars and offset the plow to one side if you like and off to the dirt you go .
