Wanted
Pulley for FEL pump
6 replies to this topic
#1 sandhopper2 OFFLINE
sandhopper2
  • 6 Thanks
  • 32 posts
Posted January 29, 2016 - 05:14 PM
I need a pulley for the FEL pump 7/16 bore 3 inch od 5/8 belt 1/8 keyway
#2 classic ONLINE
classic
  • 4,300 Thanks
  • 1,921 posts
Posted January 29, 2016 - 06:46 PM
Sounds like you need a pulley for a Cessna hydraulic pump. I have one of those pumps on my Cub 147 with a Johnson loader and I heard that those 7/16" bore pulleys are hard to find. Some people use a cast pulley with a separate hub, most likely a taper lock bushing.
#3 Phluphy OFFLINE
Phluphy
  • 308 Thanks
  • 401 posts
Posted January 29, 2016 - 07:12 PM
Good luck with finding that particular pulley. Have had one on a shelf for over 15 years, maybe 20, that came off of a Roper FEL and was the only reason I ended up selling the tractor. Have plans for using the pump, if I can ever find the right pulley or figure out how to modify one to work.
#4 MH81 ONLINE
  • 29,196 Thanks
  • 29,412 posts
Posted January 29, 2016 - 07:22 PM
http://www.agrisuppl...ries-x/p/18215/
http://www.amazon.co...Y/dp/B00BW5NRYI
Couple of options?
  • KennyP, Cvans and classic have said thanks
#5 boyscout862 ONLINE
  • 10,942 Thanks
  • 8,200 posts
Posted January 29, 2016 - 08:02 PM
When I can get to my lathe, I just make a bushing to fit in the pulley or bore the pulley out. I made a sleeve bushing for the engine to PTO clutch on my Wheelhorse 35 years ago and hasn't slipped yet. Cut the slot through the sleeve and then fitted a larger key with a file. You might try a piece of 3/8" pipe and bore it out. Check that it will press into a 1/2" or 5/8" pulley. I cannot justify the money for a set of broaches so, I just use a file and time. Good Luck, Rick
  • MH81 and classic have said thanks
#6 classic ONLINE
classic
  • 4,300 Thanks
  • 1,921 posts
Posted January 29, 2016 - 08:32 PM
This is interesting. Making a keyway in a pulley with a lathe.
  • limebuzz, Cvans, boyscout862 and 2 others have said thanks
#7 sandhopper2 OFFLINE
sandhopper2
  • 6 Thanks
  • 32 posts
Posted February 01, 2016 - 05:13 PM
had mine fixed
