Bolens Parts Database?
98 replies to this topic
#61 wilberj ONLINE
wilberj
  • 5,096 Thanks
  • 5,625 posts
Posted February 06, 2016 - 10:03 AM
Thanks, Jerome. That is good information to know, although I am surprised that Bolens never issued one and went on to the -03 & -04 numbering.
They offered a supplement to the 1886-01 operation manual showing the changes on the dash that is it.  I have never seen a 1886-02 parts list and I have stacks of paper work.
  • LPBolens said thank you
#62 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted February 06, 2016 - 11:36 AM
Can you scan the supplement for me? My fleet does not have a bunch of 1886's in it, so I never bothered to collect a full set of related paperwork.
#63 wilberj ONLINE
wilberj
  • 5,096 Thanks
  • 5,625 posts
Posted February 06, 2016 - 11:40 AM
Right now I don't have a good scanner.   It does not list any part numbers on it.    I could take photo with my camera if that is ok?
#64 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted February 06, 2016 - 12:25 PM
Yes, even that would be very helpful. Thanks!
#65 wilberj ONLINE
wilberj
  • 5,096 Thanks
  • 5,625 posts
Posted February 06, 2016 - 12:37 PM
  • Bolens800uk said thank you
#66 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted February 06, 2016 - 01:15 PM
Perfect, Jerome! So I can take the Parts List for the 1886-01 tractor, and change the choke, throttle and dash part numbers to the ones for the later tractors, and create my own Parts List for the 1886-02 tractors. Easy!
  • OldBuzzard and blackjackjakexxix have said thanks
#67 Bolens800uk OFFLINE
Bolens800uk
  • 1,845 Thanks
  • 1,208 posts
Posted February 06, 2016 - 01:49 PM
I don't use any Apple products, so I don't know the answer to your specific question about downloading with an iPad, except to say that the download should work on a Windows-based PC. I thought that there were viewers that you could use on Apple products, but I cannot say for sure.
I will have to borrow my wife's laptop or my so 's to have a look at what you are compiling.
#68 slf-uk OFFLINE
slf-uk
    Bolens
  • 383 Thanks
  • 155 posts
Posted February 07, 2016 - 12:42 PM
Andrew, you can download the MS Excel app from the App Store or use numbers. Just tried both and they work well.
Spreadsheet looks great
Iain
Edited by slf-uk, February 07, 2016 - 12:45 PM.
  • LPBolens and Bolens800uk have said thanks
#69 Bolens800uk OFFLINE
Bolens800uk
  • 1,845 Thanks
  • 1,208 posts
Posted February 07, 2016 - 12:58 PM
Thanks Iain.
#70 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted February 09, 2016 - 12:17 AM
There is at least one other part you would need to add for the -02. which is a heat shield that attaches just in front of the brake pedal on the right side of the tractor.
The 1886-01 didn't have that and it WILL cook your leg if you don't put some sort of deflector there.
I know that Bolens issued a service bulletin on that and later offered a rubber deflector for retrofitting.
It would be #157 on page two of the 1886-03-04 parts manual.
Here's a pic of my1886-02 with it outlined in red.  It's kind of hiding behind the lift handle for the mid-mount grader blade.
Edited by OldBuzzard, February 09, 2016 - 12:18 AM.
  • LPBolens and blackjackjakexxix have said thanks
#71 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted February 09, 2016 - 12:30 AM
Thanks, OB! I will make that addition. I am almost done with the Large Frames. I just need to wrap up the HT23's in all their glory (and confusion in the Parts List)
#72 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted February 09, 2016 - 12:54 AM
OK, now THIS is weird.
I just looked at my copy on the -01 parts list and it shows that deflector.
I know danged well that NONE of my -01s had that as original equipment
The only two that have deflectors is one that has a piece of rubber pop riveted on as per the service bulletin, and the forklift that has the #172 2942 part on it. That part was not on the forklift when I bought it, but was added during the restoration.
Here's a pic of my -01 with the 'service bulletin' pop riveted piece:
And a pic of the Forklift with the #172 2942 part on it:
  • LPBolens, blackjackjakexxix and Bolens800uk have said thanks
#73 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted February 09, 2016 - 08:51 AM
The 1886-01 Parts List shows that right side heat deflector as P.N. 1722942.
The 1886-03/04 Parts List shows the same diagram, but the P.N. is 1723530.
Maybe the change was from rubber to metal?
#74 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted February 09, 2016 - 12:36 PM
As far as I know, no 1886-01 left the factory with that part on it.
If you check both heat shields, you will see that they have different numbers as well.
#75 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,981 Thanks
  • 2,476 posts
Posted February 09, 2016 - 05:01 PM
Sometimes Bolens would send out revisions of the Parts Lists.  .....Check the Form # on your parts list.    ....It may indicate if it is a revision.
For example, my parts lists for the 1250 tractor appears as such:
Model # 197-01 = Form # P-551691 - dated 1/67
Model # 197-02 = Form # P-551691-1  dated 5/67
Model # 197-03 = Form # P-551909  - Revised & Reissued 5/69 - Replaces Issue of 12/67
My manuals are not a complete set by any means.  ...Some are the early printing before a later revision was issued.  ....Many were supposed to be discarded, according to Bolens.
Bolens advised the dealers to insert the latest revision and to remove & discard the prior printing from their binders.
  • Bolens 1000, OldBuzzard, LPBolens and 2 others have said thanks
