fitting for hydrolic outlet on narrow framed hydrostat
3 replies to this topic
#1 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 28, 2016 - 04:28 AM
I have a Johnson 20 loader that my dad bought in the 70s it was on a narrow framed gear driven cub I no longer have that cub but I want to put it on a hydrostat  is there an outlet so I do not have to use a belt driven pump the newer cubs with vertical engine   with power steering use outlet on hydros thanks for your imput
  • chieffan said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted January 28, 2016 - 05:25 AM
Not sure on your tractor, but most GT's hydraulic systems aren't large enough to handle a loader and a separate pump and oil reservoir are needed.
  • chieffan and bill edler have said thanks
#3 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted January 28, 2016 - 06:46 AM
For the loader you will still need that pump. The hydro can run little things like power steering and a blade or deck lift functions, but it doesn't have the gpm or volume for oil storage needed for a loader.
The larger SCUTs with the big tough torq transmissions will, but not a gt sized unit. You will need to still use the loaders resivoir and pump.
#4 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 28, 2016 - 03:26 PM
just thought it would be easer without external pump thanks for the imput
