Bolens guys I need some Diesel help!
7 replies to this topic
#1 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted January 26, 2016 - 11:00 PM
I offered to help a friend out  :hitting_self_roller: and work on his Iseki for him. It was overheating and he thought that it might have a blown head gasket or a cracked head. He had the tractor tore down to the engine and it sat like that for 3 years. He asked if I would look at it for him. Before I pulled the head I contacted Lubbock Gasket and they assured me they could make a head gasket for it which they later did. Now it is time to reassemble the engine and I need to know what the torque is for the head and rocker arm bolts. It's an Iseki TX1210 F. 2 cylinder Diesel and around 14 or 15 HP.  Is or was there a model of the Bolens diesel tractors that was comparable to this and would any of you know what to torque the head bolts?
Any help would be greatly appreciated  :thank_you:
#2 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted January 26, 2016 - 11:32 PM
Give this guy a call,his name is Robb,he's pretty good with those tractors, (610)405-1835
  • Cvans said thank you
#3 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted January 27, 2016 - 11:02 AM
Will do and thanks for the suggestion.
#4 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted January 29, 2016 - 06:28 PM
Robb was a big help and knows his Bolens diesels. A real Gentleman.  :thumbs:
Thanks again for the suggestion.
#5 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted January 29, 2016 - 07:57 PM
Chris, what was the torque spec? And was this the Mitsubishi?
#6 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted January 29, 2016 - 08:05 PM
Tractor = Iseki 1210 F
Torque = 94 to 101 FT. Lbs.
Robb did say that a Mitsubishi dealer could have parts.
No torque sequence was specified but I will start in the center and work out starting at 50 FT. Lbs. and working my way up 10 Ft. Lbs. at a time.
  • Cat385B said thank you
#7 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted January 30, 2016 - 12:07 AM
5-2-4
3-1-6
  • KennyP and Cvans have said thanks
#8 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted January 30, 2016 - 10:41 AM
5-2-4
3-1-6
Took me a second but I think that's the idea I had in mind.  :thumbs:
