Moto Mower 6020 and implements
19 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted January 26, 2016 - 09:05 AM
I have a list of implements that I want to pull this summer. I need opinions on whether each is a good or bad idea.
8" moldboard plow. Used to be a horse plow if that matters
33" offset atv disk. Notched blades and will be adding weight.
Homemade row crop cultivator. Made with 3 12" chisel plow sweeps bolted to international C shank cultivator shanks.
Thanks in advance on your input.
#2 MH81 OFFLINE
Posted January 26, 2016 - 03:25 PM
I would think it would be fine, just be mindful of sudden shocks. That's where the damage could occur.
Keep the speed down on the plowing and be ready for rocks. Same with the cultivator.
  • Greasy6020 said thank you
#3 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted January 26, 2016 - 03:59 PM
Ok. Thanks. When you say keep the speed down that means 1st gear at 3/4 throttle or about there (under 2.5 mph)? At my place there isn't much to speak of for rocks because most of them are picked out and put wherever they aren't in the way. I might have a row crop gt sized cultivator around unless it went with grandpas massey ferguson... That could work better.
#4 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted January 26, 2016 - 04:38 PM
I would consider finding a different tractor. you bust up that transaxle good luck finding parts for it
#5 James Bosma OFFLINE
James Bosma
  • 1,149 Thanks
  • 581 posts
Posted January 26, 2016 - 05:42 PM
I was thinking the same thing about the transaxle, Just looked at those tractors and IMHO i wouldn't try working the feilds with it.
​It is your tractor and can do what you please with it
If you plow with it and it has a major break down at least your being warned and hope you don't get too mad at yourself
Did Moto Mower offer these attachments when they were new?
I think you should get the 12 HP Massey going and use it or buy bigger
I have a MF14 and compared to the Moto Mower the Massey is a tank and I also know there is a few years between them
#6 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted January 26, 2016 - 08:44 PM
Since the MF exec and moto-mower GTs have the same transaxle, this should help answer some of the questions:
http://www.simplicit...executive2.html
My suggestion would be to avoid the temptation of loading on a lot of weight.
Edited by motobreeder, January 26, 2016 - 08:45 PM.
  • DH1 and Greasy6020 have said thanks
#7 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted January 26, 2016 - 09:26 PM
Going by the opinions so far... I'm gonna have to start bargaining with the guy that bought grandpas massey ferguson 12...
#8 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted February 10, 2016 - 05:46 PM
I have another question regarding my Moto Mower and various implements. Would my Moto Mower have any trouble whatsoever pulling a brinly row crop cultivator In sandy ground? Would pulling a cultivator be considered light duty work?
Thanks for your time
#9 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted February 10, 2016 - 05:48 PM
I don't think it's an issue my only concern would be if you bust something on the tractor moto mower parts are not that easy to come across anymore.
#10 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted February 10, 2016 - 05:54 PM
Agreed. I don't want to break anything... That's why I'm getting more opinions. I've only ever seen one more transaxle EVER. I think I know of another Moto Mower locally. Actually it is just down the street from where I bought this one.
#11 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted June 02, 2016 - 12:53 PM
Sorry for digging up an old thread, but I have more questions... In the massey ferguson exec brochure, there is a plow cultivator and disk for use with the massey ferguson exec, that leads me to the conclusion that I probably could put the Moto Mower to work with light ground engagement work.
Now, I know there are risks to go along with this plan. I have heard that the rear axle is potentially delicate, that I should avoid jerking the tractor around or using ground engaging work. Parts are also very hard to find
#12 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted June 02, 2016 - 04:46 PM
Yes you can put it to work.
The tractor has skinny rear tires, not a lot of traction compared to a larger tire with lots of weight on it, so your trany will be fine.
Add bigger tires and too much weight then ??? you start pushing the trany harder.
IamShewood is the guy you want to talk to he has all the Executives with attachments.
#13 MH81 OFFLINE
Posted June 02, 2016 - 05:03 PM
That's him on the tractor in the white suit
  • DH1 and motobreeder have said thanks
#14 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted June 02, 2016 - 05:53 PM
Can't decide if you're yanking my chain or not... If it is him, pretty cool!
#15 MH81 OFFLINE
Posted June 02, 2016 - 06:18 PM
Sorry, Will was here more before you joined.
He is both older and bigger than that gent.
And his suit would be lavender, not white.
  • DH1, IamSherwood and Greasy6020 have said thanks
