Long term fuel
18 replies to this topic
#1 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted January 24, 2016 - 10:09 AM
With the way gas lasts now is crazy. But I have found a way that last . I work for a race car shop full time, but my part time job is getting cars up and running for the Collings Foundation where they have a wide collection of cars planes and tanks. Over the years I have gotten a lot of cars up and running for them . One in fact was a car owned by Al Capone. Last time it ran was 1978. In 2011 I was asked if I could get it running, after Rebuilding the frozen water pumps and starter and a few tricks. I got it running. Well we use the car for about an hour 2 times a year. All of the cars that I get running I have been using avgas it has a 7 year life span. I have tried all different additives and nothing lasts. I also put in a like mystery oil to loosen things up.
www.collingsfoundation.org
  • Gtractor, KennyP, boyscout862 and 4 others have said thanks
#2 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted January 24, 2016 - 11:34 AM
I thought that AVGAS was hazardous to car engines. A friend put AVGAS in a jeep and the engine blew. I was warned against it too when I had a jeep. Sounds like really cool jobs that you have. Good Luck, Rick
  • Chris11 and chieffan have said thanks
#3 chieffan ONLINE
  • 10,199 Thanks
  • 6,659 posts
Posted January 24, 2016 - 12:30 PM
Ad Sta-bail and keep the gas in a tightly closed container under cover and it will keep a long time.  6 month anyway.
  • Chris11 said thank you
#4 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted January 24, 2016 - 01:07 PM
It is leaded It burns slower. Not good for newer cars with o2 sensors
#5 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted January 24, 2016 - 06:53 PM
I love watching these post apocalypse shows where cars have been sitting for a couple of years and the gas is still good. I just laugh every time the siphon some out of an abandoned vehicle.
Somehow the batteries stay charged too.
  • MH81, Chris11 and LilysDad have said thanks
#6 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted January 24, 2016 - 07:23 PM
Ya I see that to. Every time I start working on one the first thing I do is pull the plugs oil the cylinders put them in 3rd gear and rock them back and forth. Make sure there not stuck. Then make sure theres oil in it. Pull fuel line off and drain them. Hook up a battery to see if the crank over. I turn them over till I have oil presser Then check for spark. If I have all that I put up a iv bottle of fuel to see if they kick. Every car I have worked on there the fuel tanks are full of varnish. carbs too. rust and dirt. I really enjoy getting them started after 35 years.
#7 Jazz ONLINE
Jazz
  • 2,406 Thanks
  • 1,449 posts
Posted January 25, 2016 - 10:48 PM
I avoid ethanol like the plague. Seems to have a short shelf life. I also drain any carb that is not going to be used for a few months, its worth the little time it takes to avoid trying to start a generator thats been sitting for 2 years full of fuel on a cold dark night only to find a thick film of yellowy scum plugging up the fuel system.
#8 MiCarl ONLINE
MiCarl
  • 2,050 Thanks
  • 1,057 posts
Posted January 26, 2016 - 08:35 AM
Here in the states it's getting hard to find gasoline without ethanol blended in.
Occasionally I'll get a motorcycle in my shop that has been sitting since before they started putting ethanol in the fuel.  Generally those carburetors will be in better shape than something that sat for a few months with "modern" fuel in it.  Also, the fuel tank isn't all rusty like one that sat with gasohol in it.
Every engine I have gets sta-bil treated fuel if it's going to sit for more than a couple weeks and I keep the tanks full to cut down on condensation.  My occasional use stuff (snowblower, chain saw, generator) only get treated fuel.
#9 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted January 26, 2016 - 11:04 AM
Haven't had much luck with the sta bil  maybe oh for a few months but not a year.
#10 Billy M ONLINE
Billy M
  • 670 Thanks
  • 547 posts
Posted January 26, 2016 - 04:33 PM
I switched to premium gas in all of my small engines years ago.  I haven't had any gas go bad on me yet.  I don't think there is any scientific documentation to back it up.  It just seems to store better.  I also switched to Pri-G from Sta-Bil a few years ago.  I've been very happy with it as well.  I use it in every can of gas when winter starts approaching.  I'll run plain gas through the summer months when I know I'll be using it up quickly.  Pri-G also claims to freshen up bad gas.  I don't know how "bad" the gas can get before it's gone too far.  I've used it for that before, and it seemed to help.  I did burn all of the bad gas.
http://www.amazon.co...6/dp/B0000AXY97
  • Chris11 and Eric have said thanks
#11 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted January 26, 2016 - 04:47 PM
I put premium in the Hemorrhoid and it blew the head gaskets. Although that just may be that stupid tractor.
  • limebuzz and Chris11 have said thanks
#12 Billy M ONLINE
Billy M
  • 670 Thanks
  • 547 posts
Posted January 26, 2016 - 05:17 PM
I would say it was the tractor.  It sounds like it's a PITA!  (Pun intended!) :D
The fuel grades are basically the fuel's resistance to causing pre-ignition or knocking.  It's used mainly on high compression or boosted engines.  Higher grade fuel doesn't necessarily burn hotter or give you more power.  Although, I believe the small engines I've ran it in appear to run better.??  I mainly use it because I've never had it go bad on me since I've switched.
Edited by Billy M, January 26, 2016 - 05:19 PM.
#13 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted January 26, 2016 - 09:57 PM
The Hemorrhoid kept backfiring terribly with high test.  Even after I replaced the head gasket it did it. Went back to 87 and all was well.
#14 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 26, 2016 - 10:16 PM
I have at least 4 gas stations near me that have non-ethanol, but only in high test, I use this in everything but the truck, rarely have problems.
#15 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted February 05, 2016 - 10:03 PM
is that Al Capone's V16 Cadilac you are referring to?
  • MH81 and Chris11 have said thanks
