Moldboard Build
9 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 03:03 AM
that i stretched out to 8,1/2 "from a planet junior walk behind powered unit of the cousins so i set to make it & this is how it turned out
i had to change the land side heel to heavier & angle to hold in the cut wall ( trials & errors ) works good now
the share & coulter is 1 piece on this build  & of 3/16 high pressure pipe , i can turn the unit on the bar to set side angle for the land side wall with a large bolt & nut & adjust the cut pitch by adjusting the top linkage in or out
Shane
P.S. i do apologize for not more pic's time was limited to getting it all done !
  • olcowhand, Gtractor, limebuzz and 7 others have said thanks
#2 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted January 24, 2016 - 05:30 AM
Hope to see some pics of it turning dirt soon.!
  • boyscout862 and holdenboy1960 have said thanks
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 24, 2016 - 06:03 AM
That's cool, a plow that rolls to the left, all ours roll right, ouh yeah I forgot you guys down under do things opposite .... Just kidding of course, have you turned any soil under with it yet ? You folks must be getting close to harvest time ?
  • holdenboy1960, MNGB and jimmy G have said thanks
#4 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 06:12 AM
no m8 , the cut out was actually a mistake had the template on the wrong wayover but i don't care , i'll use it anyways
i hoped ya'll would not notice my mistake , but i have to find some more sod to roll 1st
Edited by holdenboy1960, January 24, 2016 - 06:13 AM.
  • limebuzz, Alc, jpackard56 and 1 other said thanks
#5 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 06:21 AM
I did some test runs to fix & set the land side & such , i have to weight my tractor for better traction but am now makeing a gt from scratch , i can not take any pic's atm run over it with the MTD been ran over 2 times now & is dead
  • KennyP, skyrydr2, MNGB and 1 other said thanks
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted January 24, 2016 - 07:23 AM
Sorry about the camera.
The plow looks good, should keep the garden going for a long time.
Can I make a couple suggestions?
1 Find some high carbon 1/4" x 2.5" and bolt it along the bottom as a wear edge. The top ledge may need removed when you put it on, but I'm sure you're capable :D.
Not that the moldboard won't wear too, but the share is going the really suffer and that might be an easy way to prolong the units life.
2 Is that toplink an old C band actuator? If so, the ones we had here like that had a cast acme nut. Would hold up to anything but sharp impact, then it'd shatter. Just a word of caution.
  • tractorgarden and holdenboy1960 have said thanks
#7 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 08:39 AM
Thank you for the suggestions , i do enjoy them as most of you people have done & made more stuff than me as it is over 35 yrs
since i used a tractor for farm work & forgotten most, much less make the stuff  just from what i have seen in here
 ya'll an inspiration for me
The top linkage was an old type car jack or trailer/ caravan hitch lift winder (jockey wheel )as we know it & this 1 has a 1
inch steel nut in side
#8 case442 OFFLINE
case442
  • 694 Thanks
  • 425 posts
Posted January 24, 2016 - 09:07 AM
Very nice job there. What make of tractor is it on?
Mike
#9 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 09:27 AM
Mike
It is a , Rover Rancher 2 , 1970's era Australian made , Blue in colour , they originally had 8 HP Briggs & Stratton some electric start & lights,  3 speed g/box  4x 8 rear tires & 2.5 x 6 fronts , but i got 8x 19.50 x8 rear straight axle & 4 x 6 front tires 10 HP IC e/s engine B&s & 5 speed g/box out of late 70's 80's Bolens rear engine rider which is the same mount up type,pulley & sprocket as well
Edited by holdenboy1960, January 24, 2016 - 09:29 AM.
  • Alc, KennyP, case442 and 1 other said thanks
#10 MNGB OFFLINE
MNGB
  • 2,704 Thanks
  • 1,605 posts
Posted January 24, 2016 - 10:50 AM
Hi holdenboy1960, nice job on the plow build, I noticed the left roll right off but as long as it works now you could build a right one and hitch them together and when you get to the end on the field just turn around and come back, There were a number of mfg the built them back a few years ago. Likewise will be watching for action photos, just don't lose your camera and plow it under :dancingbanana: :wave:
Edited by MNGB, January 24, 2016 - 10:50 AM.
  • MH81, holdenboy1960 and jimmy G have said thanks
