Build time over x/mas Implements, lift arms & tines .
10 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 02:35 AM
got a bit of time on my break to fiddle & tinker a tad , So set to making some bits to use with my Rover 2
So out with the mig , grinder & hammer lol & this is what i come up with
P4290070.JPG  < this was the start of the lift arms & 3 point tool bar  & hiller & furrow tines
this is the 3 point & tool bar nearly finished & 2 hiller/furrow tines tacked up for welding & tow hitch finished ready to use P4300075.JPG the tow hitch just bolts with 1 big bolt just nice
p.s .all steel is of decent gauge 3/16 , 12/32 . 3/8 & 7/16 Gauge steel , the hillers are 3,16 " and of 8" high pressure pipe cut out  , lift arms are 7/16 x 2" & the rest is of what  ever gauge mentioned
Shane
Edited by holdenboy1960, January 24, 2016 - 02:36 AM.
  • Gtractor, limebuzz, MH81 and 8 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 24, 2016 - 02:45 AM
Nice fab work. What does the whole machine look like?
#3 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 03:36 AM
This is my Rover Rancher 2P9080186.JPG i have refitted the tires & changed the gear box to a 5 speed & made every thing else includeing lights , stainless steel hood cover ect ect
,1970's which had a push blade & front load skid slasher & self drive rotary hoe rear fit on small 3 point linkage
it is a light application garden Tractor here in Australia unlike the Howard which was a heavier machine , bigger  tires cast iron diff & such made in the 60's & 70's like your early machines
this was the 1st ground rip with the hiller/furrow tines P5010089.JPG
Shane
Edited by holdenboy1960, January 24, 2016 - 04:33 AM.
  • limebuzz, MH81, wvbuzzmaster and 6 others have said thanks
#4 KennyP ONLINE
  • 38,309 Thanks
  • 45,901 posts
Posted January 24, 2016 - 05:15 AM
That's got a long wheelbase! The rip looks good!
#5 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 06:33 AM
Kenny, the wheelbase is the same as the MTD 2001 13,38 & JD Sabre 2002 17.5, 42 riders within the inch
#6 MH81 OFFLINE
Posted January 24, 2016 - 07:14 AM
Glad you got some productive shop time.
It always feels good to create something useful.
#7 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted January 24, 2016 - 07:24 AM
Looks pretty cool! Your fab skills look good, if you only had a heavier Tractor you would be really be able to have fun. It's really challenging to make a lite duty machine do the work of a heavier duty unit. In most cases it causes more effort than needed and something breaks, or it just won't do what you intended and leads to great frustration.
I have been there..... and in some cases still there LOL. Keep up the good work!!
#8 KennyP ONLINE
  • 38,309 Thanks
  • 45,901 posts
Posted January 24, 2016 - 07:33 AM
I meant the length. It looks much longer.
  • boyscout862 and holdenboy1960 have said thanks
#9 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 08:27 AM
SHOP Time , hell yeah just loved it getting creative for a change ,crazy with welder & grinder but the funny thing is it takes longer to find what i'm going to use than it does to make it. A week to plan & a day or two to make
As for the tractor it is a tad light for a good job but it is slow & straight axle ( not diff )which helps a lot
in the middle of making a bigger GT ut no camera atm
  • KennyP and MNGB have said thanks
#10 MNGB ONLINE
MNGB
  • 2,119 Thanks
  • 1,407 posts
Posted January 24, 2016 - 10:57 AM
Hey holdenboy, good fabrication and its doing the job, what is your intended use for it looks like it will be good for hilling up rows.
#11 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 11:10 AM
it is to be universal tool, hilling & furrow cutting for potatoes & such as well, but i have to make 2x 1/2 tine's so i can have more width between the rows
 the test dig was in hard sod, drove on ect, but built it heavy so to use on a bigger GT later
  • MNGB said thank you
