8-N problems
10 replies to this topic
#1 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted January 23, 2016 - 03:02 PM
I know this isn't a "garden tractor" but I thought you guys could answer a question I have. we got all of this snow and so we when to go start the 8-n and it seemed as though it was missing any suggestions on how to fix this the last time it ran was fall.
  • MH81, chieffan, CharlesDes and 2 others have said thanks
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,307 Thanks
  • 4,948 posts
Posted January 23, 2016 - 03:08 PM
Points may be dirty.  Is it a side distributor or front?
  • chieffan said thank you
#3 chieffan OFFLINE
  • 10,089 Thanks
  • 6,612 posts
Posted January 23, 2016 - 03:14 PM
Let it warm up good and see if it smooths out.  Could be a partially fouled plug.  Choking to start it caused it to foul out till it gets burned off.
#4 Bolens 1000 ONLINE
  • 14,978 Thanks
  • 18,136 posts
Posted January 23, 2016 - 03:24 PM
Could be a simple fouled plug as mentioned above.
#5 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted January 23, 2016 - 03:35 PM
Check the ignition wires for mice chewing on them too. I think we have a manual for the 8N in our Manuals Section. Good Luck, Rick
#6 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted January 23, 2016 - 04:16 PM
Water in gas, or in bowl?  Have a drain to let some gas out of bowl a bit?  WD40 or other sprays will "dry" out wires and cap maybe. I would also just run some if hasn't been used in long time. Let it warm up good.
  • Bmerf and chieffan have said thanks
#7 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 23, 2016 - 07:10 PM
Gas may have separated. Had that happen one time. Good running machine filled up and sat for ~month. Go to start and nothing. Twelve hours later, after changing everything, (plugs, cap, wires) Decide to drain full tank out. Pour some in a can and drop in match. Would not light! New gas; purred like a kitten. Never bought gas at that station again.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted January 23, 2016 - 08:13 PM
You have got a lot of good advice. This site has a lot of very helpful members with a lot of experience.
There is a site that anyone running an old Ford should have bookmarked for reference.
Look up Smiths old Ford Tractors and bookmark it.
  • tractorgarden and boyscout862 have said thanks
#9 MH81 OFFLINE
Posted January 23, 2016 - 09:20 PM
If you have a set of Hot pliers (plastic pliers for dealing with high voltage), you can pull one wire at a time and see which one isn't firing.
If you suspect plugs, look for the one with the c on it, that's the one I'd suspect.
  • Bolens 1000 said thank you
#10 Bolens 1000 ONLINE
  • 14,978 Thanks
  • 18,136 posts
Posted January 23, 2016 - 09:22 PM
If you happen to have the old school exposed wire plug clips my grandfather always used to check with a long handle screw driver and grounded it on the block, if it started missing you knew that one was firing, if you didnt hear any mis fires grounding a plug you knew it was the one giving you trouble.
  • olcowhand, MH81, boyscout862 and 1 other said thanks
#11 olcowhand ONLINE
  • 41,019 Thanks
  • 31,379 posts
Posted January 23, 2016 - 09:35 PM
Could also be a bad distributor cap, or it's damp inside it.  If spark all checks out, try draining the carb.  May have some water in there.
  • Bolens 1000, boyscout862 and BNK have said thanks
