got the 1250 home
36 replies to this topic
#31 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 01, 2011 - 04:14 PM
Well its been a while I finally got some more time to spend with the 1250. I did get it started today while spraying fuel into the carb. but it will not run on its own. Going out to pull the carb off after dinner and give it a good cleaning.
#32 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 01, 2011 - 07:07 PM
Sounds like your on the right track.
Keep us updated
#33 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 02, 2011 - 09:19 AM
Carb looks pretty nasty. is there something I can soak it in to clean it? I'm not much of a carb guy:confuse: so I don't want to tear it apart any more than I have to.. Wont have time to mess with it too much today leaving here in about 20 minutes to go pick up the new to me 1220:smile1:. and when I get it here I have to take the ugly weight off it..
#34 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 02, 2011 - 08:06 PM
I soak my carbs in a solution called "Awesome" Takes the gunk right out.
Its very cheap as well.
I'm sure there are specific solutions for carb cleaning but it works fine for me.
  • DGS345 said thank you
#35 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 02, 2011 - 08:33 PM
awesome orange, gets grease off anything, buy it at the dollar store. but dont buy out my local dollar store =)
#36 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted July 02, 2011 - 08:46 PM
While your checking the carb, spend the time to check the fuel pump. If it dosnt pump or pumps weak, I suggest going with an electric pump. It will help with start up's alot.
#37 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 03, 2011 - 08:01 AM
I will check the pump it also wont start without a jump battery tests ok but this thing needs to be jumped every time with my truck running? could it be the starter generator?
