got the 1250 home
#16
OFFLINE
Posted April 26, 2011 - 08:58 PM
#17
OFFLINE
Posted April 29, 2011 - 01:13 PM
#18
OFFLINE
Posted April 29, 2011 - 03:14 PM
- NUTNDUN and DGS345 have said thanks
#19
OFFLINE
Posted April 30, 2011 - 02:13 AM
#20
OFFLINE
Posted April 30, 2011 - 04:32 AM
#21
ONLINE
Posted April 30, 2011 - 05:44 AM
#22
OFFLINE
Posted April 30, 2011 - 09:24 AM
There is no part under the weights the bolts go into the lug holes. if you understand what I'm saying.Dan, good save there. Hope you get it going. On the tractor #s being unreadable, try looking at an angle with light just right you can some times see them. I like the way the weights attach, what does the part under the weight look like?
#23
OFFLINE
Posted April 30, 2011 - 09:39 AM
Model S-12
Serial No. 4808334
Spec No. 294257
I have had no luck locating points locally from the numbers given above. Any one know a source let me know
thank you
#24
OFFLINE
Posted April 30, 2011 - 11:53 AM
There were two styles of lift levers for the hydraulic control. The 1967 version was straight after making the bend out of the dash tower. For 1968 and 1969, the lift lever was bent again towards the rear of the tractor, making it easier to grab the lever without banging your knuckles against the dash tower.
- DGS345 said thank you
#25
ONLINE
Posted April 30, 2011 - 01:19 PM
Also if anyone can help ID the year the numbers on the engine are as follows.:
Model S-12
Serial No. 4808334
Spec No. 294257
thank you
The engine was made in January 1969
#26
OFFLINE
Posted April 30, 2011 - 09:20 PM
#27
ONLINE
Posted May 01, 2011 - 07:55 AM
Dan, I checked my three 1250's just to be sure on the Spec. No. and found them all to be #281960, just like the literature says they should be.
The engine Must have been replaced not too long after the 1250 was purchased
Mabye the engine blew up a year after it was produced and they threw the 69' in there
#28
OFFLINE
Posted May 01, 2011 - 01:01 PM
#29
OFFLINE
Posted May 01, 2011 - 06:17 PM
Dan let us know when you get her running. I think you will love the tractor and I see more large frames in your future
I know he will LOVE this tractor. My 1250 is one of my favorites. I just cut the grass for the first time today with it.
#30
OFFLINE
Posted May 01, 2011 - 06:18 PM
I've thought the same with my 1050. And I also think that is a very reasonable guess.
