got the 1250 home
#1
OFFLINE
Posted April 25, 2011 - 09:08 PM
#2
OFFLINE
Posted April 25, 2011 - 09:22 PM
#3
OFFLINE
Posted April 25, 2011 - 09:56 PM
#4
OFFLINE
Posted April 26, 2011 - 07:32 AM
#5
OFFLINE
Posted April 26, 2011 - 09:35 AM
#6
OFFLINE
#7
OFFLINE
Posted April 26, 2011 - 11:23 AM
Nice buy, hope you can get her running.
I have a feeling the plate in front is not original...Could be wrong though
#8
OFFLINE
Posted April 26, 2011 - 12:09 PM
That construction on the front looks very sturdy, but it is not stock.
#9
OFFLINE
Posted April 26, 2011 - 01:09 PM
#10
OFFLINE
Posted April 26, 2011 - 01:33 PM
I already took off the plate on the front, I was sure it was not original. It was very well made whatever it was. I took the weights off to have them blasted. Will have to see where things go from here I hope when I get it fired up all is well.
Is green the original engine? and if so could i get year of tractor from engine #s The numbers on the tractor can't be read
#11
OFFLINE
Posted April 26, 2011 - 01:38 PM
- DGS345 said thank you
#12
OFFLINE
Posted April 26, 2011 - 01:47 PM
Edited by DGS345, April 26, 2011 - 01:52 PM.
#13
OFFLINE
Posted April 26, 2011 - 03:37 PM
Sounds like the points need to be cleaned or replaced.
If you have the serial # on the engine you can get a year.
The wisconsins were painted that green color from the factory. I never understood why some were painted Bolens brown and some were left green.
#14
OFFLINE
Posted April 26, 2011 - 04:15 PM
According to the Wisconsin manual for the engine, the breaker points gap for the S12D should be set at 0.020". Although you might get away with reusing the existing points, if it were my choice, I would replace both the points and condenser, then go on from there.
- Bolens 1000 and mjodrey have said thanks
#15
OFFLINE
Posted April 26, 2011 - 05:57 PM
Can you get me a pic of the hydro lift lever? It's one way to find the year.
