3spd trany leak
5 replies to this topic
#1 bill3t OFFLINE
bill3t
  • 44 Thanks
  • 77 posts
Posted January 22, 2016 - 02:44 PM
ive ben restoring and   tinkering around with a 74 jim dandy on and off about 2years now. discoverd whythe tranz leakd out the front. the lower case gears shaft was never installed all the way thru the box. leaving a small amount of room for oil to  leak out. with the rod all the way in the gear wouldnt turn free. so sombody left it loose. im sure the bering inside the gear got dinged up.going to find my old man glasses this afternoon and get a better look. give it a litttle dremel fix and see how it goes. i think this liittle tractor left the line to quick on a friday afternoon. bill
#2 boyscout862 ONLINE
  • 10,336 Thanks
  • 7,830 posts
Posted January 22, 2016 - 05:30 PM
You are probably right. I've seen many new defective cars. The 63 Chevy with a 283 could have the automatic choke in backwards and many were. Good Luck, Rick
#3 glgrumpy ONLINE
  • 6,971 Thanks
  • 6,736 posts
Posted January 22, 2016 - 05:57 PM
Lower shaft should be held in place by a metal tab and small bolt on one end of it. Tab slips into the shaft with slot. OR, maybe I'm thinking of the reverse idler gear shaft way down low also. Perhaps that idler has moved and is holding the lower gears back out of place? There are bushings on that lower shaft that can wear out and cause shifting of gears out of plane and or cause jambing. Sounds like maybe pulling it and going over it,with overhaul would be good idea.  Change the front and rear bearings to sealed ones then also, to keep oil in trans better. New bushings in that lower shaft cluster and check all the gears for wear and roughness.
  • Alc and MNGB have said thanks
#4 bill3t OFFLINE
bill3t
  • 44 Thanks
  • 77 posts
Posted January 23, 2016 - 10:06 AM
i found the bushing was alittle dinged up about a 1\4inch in from end. gave it a lite filing and gear turns good on rod now. the other end sombody bent the flat metal tang up at a angle just touching the rod and not in the slot. if the tranz leaks again i will replace the bushing. bill
#5 glgrumpy ONLINE
  • 6,971 Thanks
  • 6,736 posts
Posted January 23, 2016 - 04:13 PM
I think it is just the general nature for these old designs to leak a bit, seeing no seals there. Just like old BIG tractors, they just have leaky areas and you know then that it has oils and greases working there. Kinda like an old Harley or British bike, they Just leak!
#6 bill3t OFFLINE
bill3t
  • 44 Thanks
  • 77 posts
Posted January 24, 2016 - 09:48 PM
someday when i get tired off fixing stuff . will wrap old trucks and tractors in depends!!!   got a pair as ajoke gift  at my 50th.
