snow blower dolley
19 replies to this topic
#1 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 280 Thanks
  • 402 posts
Posted January 22, 2016 - 12:21 PM
hi im trying to build a dolley for my snow blower
  • chieffan said thank you
#2 dodge trucker OFFLINE
dodge trucker
  • 1,561 Thanks
  • 2,040 posts
Posted January 22, 2016 - 01:27 PM
Is it a trac drive or an attachment for a gt?
#3 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 280 Thanks
  • 402 posts
Posted January 22, 2016 - 01:32 PM
#4 Cvans OFFLINE
  • 5,042 Thanks
  • 5,370 posts
Posted January 22, 2016 - 01:36 PM
I used some of those 4 wheeled dollies that are used to move snowmobiles with.
  • DH1, boyscout862 and chieffan have said thanks
#5 Talntedmrgreen OFFLINE
  • 3,135 Thanks
  • 2,219 posts
Posted January 22, 2016 - 03:12 PM
I cut a 3' wide piece of discarded countertop (1" thick) to various lengths for various attachments.  I inserted some sturdy solid casters near the corners for easy rolling, and the formica on it allows any water to run off without soaking in.  No rust to worry about, and since it's one unit, I can maneuver over cracks in the concrete easily.
The downfall...they are bulky.  I lean them up against the shop wall and back the parked tractors right up to them, to avoid wasting floorspace when not in use.  I can also scoop them up with the forks easily, as my casters keep the board about 3" off the ground.
  • Cvans, boyscout862 and chieffan have said thanks
#6 BigFlash OFFLINE
BigFlash
  • 211 Thanks
  • 116 posts
Posted January 22, 2016 - 03:48 PM
It's hard to beat these thing, have a couple for moving hydro static tractors that don't run, they're  cheap, and if your persistent they'll even roll through grass. Have a tiller on them now, so handy to just be able roll the thing around.
http://www.harborfre...olly-61899.html
  • Cvans, boyscout862, Genem and 1 other said thanks
#7 tater195 OFFLINE
tater195
  • 1,652 Thanks
  • 1,117 posts
Posted January 22, 2016 - 03:52 PM
^^^ that was my suggestion too. hard to get 4 casters for $12 for a DIY cart
#8 Genem OFFLINE
Genem
  • 72 Thanks
  • 51 posts
Posted January 22, 2016 - 04:04 PM
They were 7 bucks each on Black Friday at HF. bought 4 of them,wish I had bought more. Gene
  • boyscout862 and chieffan have said thanks
#9 Jazz ONLINE
Jazz
  • 1,725 Thanks
  • 1,099 posts
Posted January 22, 2016 - 04:05 PM
I use my two wheeler hand truck to move mine around. Attachments are awkward for sure and to put it on any dolly somebody has to lift it.
#10 James Bosma ONLINE
James Bosma
  • 551 Thanks
  • 275 posts
Posted January 22, 2016 - 05:01 PM
I just put mine on a pallet and move around with a forklift, its home made from a Howard 3 wheel hydro mower, and a shop air forklift with home-made structural frame and mast. 10 hp motor, gets into the tight spots and saves my back, My father design and built it.
  • Gtractor, MH81, KennyP and 2 others have said thanks
#11 KennyP OFFLINE
  • 31,403 Thanks
  • 41,589 posts
Posted January 22, 2016 - 05:23 PM
I'd like to see more of that forklift! Looks like a good design! I have a Toro 3 wheeler I made a butt buggy out of. Might work real good for something like this!
  • Gtractor and James Bosma have said thanks
#12 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 280 Thanks
  • 402 posts
Posted January 22, 2016 - 05:38 PM
well i jest need it for a shed so its esay to tack off and on when the snow come's
#13 chieffan OFFLINE
  • 6,947 Thanks
  • 4,974 posts
Posted January 22, 2016 - 06:18 PM
The less number of wheels and the bigger the wheels, within reason, the better they will work.
#14 James Bosma ONLINE
James Bosma
  • 551 Thanks
  • 275 posts
Posted January 22, 2016 - 06:28 PM
Will take some pictures tomorrow and start a new thread on it tomorrow night, don't want to hijack this thread
  • Gtractor and KennyP have said thanks
#15 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted January 22, 2016 - 06:40 PM
I have a couple of old ones from the warehouse.
One is steel framed and smaller casters, used it permanently for Ryan's blower.
I have a bigger one that's made out of 2x4's and has all four wheels that swivel. Don't do that to yourself, make two of them fixed so you can wheel the thing like a car or a rear steer, not swerve around like a drunk in clogs.
Anyways, the smaller one on each end might be easier to load it onto, but then you would need to be on both ends to steer and push and make sure they stay. Maybe use a ratchet strap?
