2-8-8-2 Locomotive
78 replies to this topic
#46 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,309 Thanks
  • 1,942 posts
Posted March 02, 2016 - 10:01 AM
Willie, that engine shows No steam and smoke in that video. Early I could see a Diesel engine behind it.  Couldn't be being pushed could it?  Something isn't right there.
You have to look really close, but you can see steam coming out of the valve rod packing at the top of the steam chest.
There is also steam from the generator exhaust and a blow off line in front of the smoke stack.
These can be seen when the locomotive passes some trees early in the video.
A good engineer and fireman will adjust the controls for optimum performance and efficiency to where the fire is burning so that it does not produce any smoke when running on a flat stretch of track.
Edited by jdcrawler, March 02, 2016 - 11:04 AM.
  • Texas Deere and Horse, KennyP, MFDAC and 1 other said thanks
#47 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,309 Thanks
  • 1,942 posts
Posted March 02, 2016 - 01:58 PM
With the locomotive setting on the table, I hold a pencil on a piece of wood and draw a line down both sides of the boiler.
Then I make a mark every two inches for where the holes will be drilled for the hand rail stanchions.
Getting all of these holes drilled straight is a little more of a problem so I built this "drill jig" that holds the locomotive for drilling.
The locomotive is held in place by rubber bands.
Then I can use my drill press for drilling the holes for the hand rail stanchions.
Do one side and turn the locomotive around and do the other side.
This way it is easy to keep the holes in a line and they are all drilled at the same angle.
  • Chris11, wvbuzzmaster, KennyP and 4 others have said thanks
#48 KennyP ONLINE
  • 41,527 Thanks
  • 47,427 posts
Posted March 02, 2016 - 06:09 PM
That took some thought process to build! Great job, Ray!
  • jdcrawler said thank you
#49 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,309 Thanks
  • 1,942 posts
Posted September 05, 2016 - 08:00 PM
It's been awhile since I posted anything on this locomotive ... I've only been able to get a little time here and there to work on it.
I cut pieces of Plastruct tubing and started gluing them together to make the steam line for the front cylinders.
The steam line is all glued together.
The steam line is mounted to the top of the front cylinders with two small hex head screws.
The steam line comes out from under the boiler to the front cylinders.
Starting to make the footplate that sits across the front of the smoke box and is mounted on the front of the chassis for the front set of drive wheels.
This is a view of the underside of front footplate.
This is the top view of the footplate with diamond tread on the cross piece.
This is how it looks when mounted to the front chassis.
I looked thru my brass parts and couldn't find a set of front steps for a locomotive so I'm going to  build a set.
I took a short section of "O-gauge" house steeps and cut them in half.
Then I cut two pieces of styrene "U" channel to use for the inside edge of the steps.
Here is how the pieces look glued together.
And how they look glued to the front of the footplate.
The support bars and cross bracing are added to the steps.
Then I formed the hand railing and mounted the headlight.
The front footplate is then mounted on the chassis.
How it looks with the front chassis setting in place under the boiler.
Edited by jdcrawler, September 06, 2016 - 08:41 AM.
  • wvbuzzmaster, KennyP, MFDAC and 4 others have said thanks
#50 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 05, 2016 - 10:39 PM
Excellent detail work as always, Ray. Keep up the progress.
#51 KennyP ONLINE
  • 41,527 Thanks
  • 47,427 posts
Posted September 06, 2016 - 04:48 AM
I'm liking it!
#52 UncleWillie ONLINE
  • 16,426 Thanks
  • 9,039 posts
Posted September 06, 2016 - 10:01 AM
I kept looking at those steps and thinking they were way too big for the train, then i realized that was only a part of the wheel assemblies. Great work.
#53 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,309 Thanks
  • 1,942 posts
Posted November 18, 2017 - 03:54 PM
It has been a while since I posted anything on this but I have finally been able to take some time to work on this locomotive again. ........
I have an old tender made out of tin that was sold as a kit back in the 40's or 50's and I have decided to clean it up and use it for this locomotive.
I put 6-wheel tender trucks under it and mounted a end-sill on the rear and installed a pin under the front for the draw bar to hook to.
The front wheels on the rear chassis and the rear wheels on the front chassis, do not have springs on them.
So I took four brass springs and soldered them onto two pieces of brass plate.
Here I'm soldering the first spring to the piece of brass plate.
Here are the two finished pairs of springs.
Then I machined a piece of styrene to fit each of the chassis.
The blocks of styrene are glued in between the frame rails.
Two holes are drilled and tapped into each block of styrene.
Here are the ends of the two chassis units with the new springs mounted in place.
This is how they look when attached to the locomotive body.
The brass springs now fill in the area above the wheel sets.
With the construction of the chassis units completed, it is time to paint them.
The bearing blocks for the wheels on the AHM frames fit snugly as they are so the frames need to be masked off so paint doesn't get into the bearing mounts.
On the rear chassis, I have installed the drive gears, motor and electrical pickups that ride on the inside of the wheels.
The parts for the valve linkage and side rods are sorted out on the table to the left of the chassis.
The valve linkage and side rods are all riveted together.
Both chassis units have the valve linkage installed.
Starting with the front chassis, the wheels are then put onto the frame rails.
And the side rods and valve linkage are hooked up.
The steam cylinders and front deck are mounted in place and the pilot wheels are installed to complete the front chassis.
The wheels are mounted on the rear chassis and the side rods installed.
Before I go any farther with this, I put it on a test track and made sure that the chassis runs smoothly.
I had already painted the locomotive and tender body's several weeks ago so all I have to do now is assemble everything and the engine is finished.
I still don't have an area for a layout yet so this locomotive will have to be content to sit on one of my display shelves with some of my other engines that I built.
Edited by jdcrawler, November 18, 2017 - 03:58 PM.
  • wilberj, KennyP, Cvans and 6 others have said thanks
#54 KennyP ONLINE
  • 41,527 Thanks
  • 47,427 posts
Posted November 18, 2017 - 04:08 PM
Awesome work on these, Ray! Should be a sweet loco when it gets to run around the tracks!
#55 CRFarnsworth ONLINE
CRFarnsworth
  • 5,229 Thanks
  • 2,273 posts
Posted November 18, 2017 - 04:12 PM
You make that look easy.
#56 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted November 18, 2017 - 05:52 PM
An eye for details!
#57 UncleWillie ONLINE
  • 16,426 Thanks
  • 9,039 posts
Posted November 18, 2017 - 06:34 PM
That is beautiful.
#58 MFDAC ONLINE
MFDAC
  • 3,649 Thanks
  • 1,739 posts
Posted November 18, 2017 - 07:33 PM
Great work Ray, thanks for the update!
DAC
#59 Leonard VanCamp ONLINE
Leonard VanCamp
  • 684 Thanks
  • 482 posts
Posted November 18, 2017 - 08:45 PM
The third shelf down on the left, is that a version of a Shay loco? Love the Camelback also.
Edited by Leonard VanCamp, November 18, 2017 - 08:46 PM.
#60 Cvans OFFLINE
  • 7,483 Thanks
  • 6,475 posts
Posted November 18, 2017 - 09:45 PM
That really came out nice. Have you got anything lined up for another project?
