Newbie here with H14
h14 stator
29 replies to this topic
#1 andyrocky1 OFFLINE
andyrocky1
  • 25 Thanks
  • 24 posts
Posted January 19, 2016 - 11:32 PM
I have been reading posts and am impressed with the knowledge. I just got an H-14 with a rototiller, a mower, and a snow caster. This is my first garden tractor and I have a few questions. So far all I have had to do was replace shear pin(s). Here is one of my first questions. The tractor does not charge the battery (actually batteries as it is hooked up now). The previous owner replaced the rectifier. The engine is the Tecumseh HH-140. He said there were 20 volts across the stator wires. From what I have read, that seems to indicate the issue is the stator.
I am not planning on fixing the stator until the spring with warmer weather as it runs now. I want to do my homework. How do I know if it is 20 or 10 amp? For some reason after reading some of the manuals online, I thought it ought to be 20 amp. However, the ammeter is marked for plus and minus 15 amps. The other reason I question which one  is due to the stator connector. The connector has the wires in a T shape. When I look at them for sale on eBay I see 20 amp with the three wires in a single line. I see the 10 amp stators with the T-shape connector. The serial number of the tractor is over 300000 if that helps.
I need to spend some time on the wiring this spring. The switch was replaced with an Oregon one at some point and I want to verify it will work properly. .
I have had fun with the snow caster so far. The traction control with chains seems to work fairly well. I think it would be better with weights (and 2 link chains in place of the 4 link) especially when I lift the snow caster.  The other snow caster issue is there is no bracket to hold the chute crank. It runs through a hole in the muffler support. Is there a drawing or part number for it. The snow caster is 18538
  • LPBolens, Traill95, Sawdust and 2 others have said thanks
  • 15135 Thanks
  • 15577 posts
Posted January 19, 2016 - 11:58 PM
Welcome to GTtalk. One of the Bolens guys will be along soon to help you out. Post some photos when can, we love pictures!
  • andyrocky1 said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted January 20, 2016 - 02:56 AM
:welcometogttalk:
#4 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted January 20, 2016 - 06:21 AM
Welcome to GTTalk !    I think one of the members here had some charging issues and was getting just 20 volts ac  too . Maybe they'll answer this for you , Al
#5 boyscout862 OFFLINE
  • 15270 Thanks
  • 10025 posts
Posted January 20, 2016 - 07:30 AM
Welcome to GTT. You picked a great tractor to start with. Add wheel weights for better traction. Check our Manuals Section for the answers to your questions too. I think there is a good manual for the Tecumseh engine that you have. There are also lots of Bolens manuals. Good Luck, Rick
#6 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 20, 2016 - 08:12 AM
Welcome to GTT :wave:
We would love to see some pictures of your machine
Here's some manuals to help you get started.
http://gardentractor...olens-1456-h14/
http://gardentractor...now-throwerpdf/
The ignition switch was special and possibly why your seeing some wire issues if someone swapped out the OEM one to make something work.
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted January 20, 2016 - 08:45 AM
:welcometogttalk: :camera:
#8 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted January 20, 2016 - 10:06 AM
Welcome aboard,you bought a nice tractor,they are heavy duty and will do all you need in most cases,there was a seperate braket to hold the shoot control rod
  • Sawdust and andyrocky1 have said thanks
#9 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted January 20, 2016 - 10:42 AM
A 10 amp stator has three pins on the plug two side by side and one in the middle above them like a triangle. The 20 amp has three pins on the plug all side by side in a row.
  • Alc, Sawdust and andyrocky1 have said thanks
#10 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted January 20, 2016 - 10:44 AM
The ignition switch should have 5 pins with the m pin grounding the magneto to kill it the should never be any power in the min pin comming from the battery to the stator
#11 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted January 20, 2016 - 10:45 AM
If you have a pic of the plug I can tell you if it's 10 or 20 amp
#12 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted January 20, 2016 - 12:01 PM
:welcometogttalk:
#13 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 20, 2016 - 12:22 PM
Welcome to GTT  sounds like a good tractor...  Watch out..!!!   they are addicting... :dancingbanana:
  • WNYTractorTinkerer, AA Hayes and andyrocky1 have said thanks
#14 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 20, 2016 - 07:44 PM
Welcome to GTtalk does your tractor have a modal and serial number?
#15 andyrocky1 OFFLINE
andyrocky1
  • 25 Thanks
  • 24 posts
Posted January 21, 2016 - 02:14 AM
Thanks for all the replies. From the description above, it has a 10 amp stator. I will post some pictures soon.
The two side by side with the middle above is what I tried to describe a "T-shaped". So it sounds like the stator is 10 AMP.
  • Sawdust said thank you
Also tagged with one or more of these keywords: h14, stator
