* * * * * 2 votes
New Cub Cadet 149: The tear-down begins!
cub cadet 149 14 hp kohler fel danco
336 replies to this topic
#241 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 09, 2016 - 01:33 AM
I was finally was able to start working on my tractor again.  It was 82 degrees today so I was able to get some more painting done.  I was also finally able to get the fender on the tractor.
  • KennyP, bgkid2966 and BNK have said thanks
#242 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted April 09, 2016 - 04:26 AM
Looking good!
  • BNK and Mark 149 J. have said thanks
#243 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 10, 2016 - 02:24 AM
Started assembling the dash tonight.  It took me a while to remember how things went back together but I slowly got it back together.
I've decided to replace all of the rusted bolts and nuts with stainless versions.  I'm not going to paint them which will save a lot of time.
                                           I haven't attached the dash yet but I wanted to see what it would look like!
Happy with how it turning out so far!
Edited by Mark 149 J., April 10, 2016 - 02:27 AM.
  • Alc, bgkid2966 and BNK have said thanks
#244 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted April 10, 2016 - 04:29 AM
I usually make a list of what bolts I'm tearing off when I take a tractor apart, and buy all new to put it together also.
Looking good.
  • Mark 149 J. said thank you
#245 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted April 10, 2016 - 01:38 PM
What did you do with all them old bolts?  I know some guys that would probably take them if they are the original IH or WP headed bolts.  They have them re-anodized to original and use them over if they are still good.
#246 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 10, 2016 - 07:44 PM
Not sure yet.
  • IHCubGuy said thank you
#247 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 10, 2016 - 07:54 PM
Took advantage of the nice weather today and sand blasted the mounting brackets for the fel.  Found a tag under the paint that I hadn't seen.  Unfortunately, the sand blaster removed some of the paint from the tag before I noticed it.
I also finished up a lot of the dash but forgot to take pictures to show you what it looks like.  Should be able to get the motor in this week and hopefully start on my driveshaft upgrade that I talked about towards the beginning of this post.  I should also be able to get most of the fel painted.
It's getting closer!!
  • IHCubGuy, EricR and BNK have said thanks
#248 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 10, 2016 - 10:50 PM
Worked on the tractor after dinner.  Tried to find my steering wheel nut but I couldn't find it.  I can't even remember what it looks like.  I'll have to look some more tomorrow.
I also put the engine in the tractor for the first time in 3 months.
I sure like the way that it looks!  I'm starting to get anxious!
  • KennyP, bgkid2966, EricR and 1 other said thanks
#249 KennyP ONLINE
  • 37,461 Thanks
  • 45,483 posts
Posted April 11, 2016 - 05:01 AM
I like it!
#250 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 11, 2016 - 10:52 PM
Finished prepping the fel mounting brackets and applied a coat of primer tonight.
  • Alc, EricR and BNK have said thanks
#251 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 12, 2016 - 11:11 PM
I was able to get 2 coats of IH white on the fel brackets today!
Hoping to have the rest of the fel parts painted by this weekend!
  • KennyP and EricR have said thanks
#252 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 16, 2016 - 01:27 AM
I've been working on the motor tonight.  I need to have the motor in place so that I can measure for my driveline upgrade.  Here is the link to the directions for the driveline modification.
http://cubfaq.com/DK%20IHCCmods.pdf
Here are some pictures of the parts I'll be using.
I'll start the engine when I finish with the driveline instillation because the gas tank will be in the way.  Here is what the engine looks like tonight.
20160415_223522.jpg 20160415_223504.jpg 20160415_223451.jpg 20160415_223443.jpg
I'll install the fel brackets when I get the motor running.  It's a lot easier to work on the motor with the fel removed.
#253 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 17, 2016 - 02:03 AM
After a busy day cleaning the outside of the house I finally was able to get out to the shop and work on the tractor.  Started with installing the support brackets for the FEL.  The brackets are installed with two long bolts around the axle tubes
and three bolts on the front frame.  They use the Frankenstein bolts as one of the attachment points.
The third bolt(right) bolts from under the front axle similar to how the engine mounting bolts.
It keeps looking better and better every time!
I also sprayed a coat of paint on the gas tank and mounting straps.
I tested the starter as well today but all I got was a load click from the starting solenoid.  I made sure the grounding cable was on the starter, battery was fully charged, and my grounding cable at the battery and front frame were contacting clean, unpainted metal.  I'll have to figure that one out on another day.
I took my driveshaft and upgrade parts to a machinist friend of my father-in-laws.  He has a nice milling machine and lathe to get every in working order.  He said he would have it done with in the next week.  I'm anxious to see how everything will turns out.
  • Alc, KennyP, bgkid2966 and 1 other said thanks
#254 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted April 18, 2016 - 07:54 AM
I had a solenoid on my 108 that would only click and it turned out to be burnt contacts inside the solenoid.
#255 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,130 Thanks
  • 1,211 posts
Posted April 18, 2016 - 09:25 AM
It's possible that during my painting process, I hit the solenoid on something that could have damaged it.  I haven't had time yet to look at it.  I'm going to try tonight.
Also tagged with one or more of these keywords: cub, cadet, 149, 14 hp kohler, fel, danco
