John deere 70 starter
4 replies to this topic
#1 637Yeoman ONLINE
637Yeoman
  • 1,582 Thanks
  • 1,281 posts
Posted January 17, 2016 - 09:10 PM
So on saturday i went to start my 70. Flipped the switch, turned the key and a HUGE spark came out the front. went to try again after making sure its not on fire, and nothing. Once and a while it will make a ticking noise. i dont know what it could be. Starter? We have a car coil up front but i dont think that would have done it and now it dosent roll over?
I dont know what to do so ill blame it on Bolens Qt-17 since he was there. hehe. :poke:
Any help would be appreciated. Thanks guys.
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 17, 2016 - 09:23 PM
  One thing to check is run a jumper cable from starter housing to the neg batt post to insure the starter is grounding good.
                                                   Mike
  • 637Yeoman said thank you
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted January 18, 2016 - 03:57 PM
Did you check the rectifier to see if the fuses are blown? It's located on the right hand side of the motor, just in front of the oil fill tube and oil drain plug.
#4 637Yeoman ONLINE
637Yeoman
  • 1,582 Thanks
  • 1,281 posts
Posted January 18, 2016 - 09:42 PM
no i havent. that would make sense though.
#5 M.Cain OFFLINE
M.Cain
  • 185 Thanks
  • 158 posts
Posted March 05, 2016 - 01:19 PM
Yep you don't ever want to put a charger on it and try to start without pulling fuse it can be trouble.
