New Boots on my Bolens 1254
24 replies to this topic
#1 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 15, 2016 - 05:36 PM
I have posted up a photo of my 1254 with its new boots. I think it looks absolutely cool and mean.
Can't wait to use her properly once the engine is sorted.........
  • daytime dave, Alc, wvbuzzmaster and 7 others have said thanks
#2 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted January 15, 2016 - 06:07 PM
It looks great with the tri-ribs on the front now. I have ag tires on the back of my 1054 now  but still have turf tires on the front. I want to get a pair of tri-ribs for front, but I have other priorities at the moment. What is the issue you are having with the engine?
Jim
  • Bolens800uk said thank you
#3 KennyP ONLINE
  • 53258 Thanks
  • 53342 posts
Posted January 15, 2016 - 06:10 PM
What brand are the tri-ribs? Alice would like a set of those!
#4 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 15, 2016 - 06:11 PM
Jim
Jim, thanks for your comments. Unfortunately it is the dreaded stator and modules are not sparking. I have added a wanted post for anyone who got a working one available.
Cheers Andrew
  • chieffan said thank you
#5 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 15, 2016 - 06:14 PM
Kenny, thanks for your comments. The tri ribs are Trelleborg T513 (4.00 - 8) from bigtyres.co.uk
Cheers Andrew
  • Alc, KennyP and chieffan have said thanks
#6 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted January 15, 2016 - 06:28 PM
Now that you mention that, I did see your wanted ad. There is a company called pertronix that makes electronic ignitions for a wide variety of applications, mainly to replace points type ignitions. I just did a search on their site, but only found stuff for the bigger Wisconsins. They do add new products all the time and they do listen to requests. There are a lot of old Wisconsins using the same setup as yours (and mine), I wonder if they would be interested in making an ignition for them. It wouldn't be original, but better than nothing.
Jim
Edit: I am going to send them an E-mail and see what they have to say.
Edited by CanadianHobbyFarmer, January 15, 2016 - 06:33 PM.
  • Alc, KennyP, TomLGT195 and 2 others have said thanks
#7 Eric OFFLINE
Eric
  • 1324 Thanks
  • 813 posts
Posted January 15, 2016 - 06:38 PM
Just rebuilt a tra10d with points eliminator and electronic ignition, worked great!
  • Alc, chieffan, Bolens800uk and 1 other said thanks
#8 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 15, 2016 - 06:39 PM
Thanks Jim; I am exploring all avenues at the moment. The 1254 is a bit of fun; in fact all my Bolens are for fun!
  • chieffan and CanadianHobbyFarmer have said thanks
#9 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 15, 2016 - 06:40 PM
Can you post up some details on how you went about this please Eric? Cheers
#10 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted January 15, 2016 - 06:57 PM
I would be interested in seeing the details on that as well. Mine is running fine right now, but it will inevitably give up some day.
Jim
#11 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted January 15, 2016 - 07:13 PM
Cheers Andrew
Andrew,there a guy on MTF saying he has some stator for the Wisconsin Bigrigs93
  • WrenchinOnIt, chieffan and Bolens800uk have said thanks
#12 chieffan OFFLINE
  • 16663 Thanks
  • 9106 posts
Posted January 15, 2016 - 08:07 PM
Those point eliminator electronic ignition modules work only with magneto ignition.  Won't work with battery ignition engines.  Have used several of them but need a good coil for them to work.  They just eliminate the points.
  • WrenchinOnIt and Bolens800uk have said thanks
#13 Eric OFFLINE
Eric
  • 1324 Thanks
  • 813 posts
Posted January 15, 2016 - 09:20 PM
Yes I may have some pics of it I will have to look in the morning. I also have a points eliminator kit for my cub 127 and it is definitely not mag ignition, I have the instructions in my shop I had to call the guy and he told me the same kit will work with any battery ignition this is how I came to do the estate keeper like this. It runs great and also did not have mag ignition. I will get the info for you tomorrow as it is very cold and dark in the barn tonight. If you want to look it up I used ignition solutions for small engines and garden pulling tractors. Great source of info and also great people to contact when in a jam!
  • Alc, Bolens800uk and CanadianHobbyFarmer have said thanks
#14 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 16, 2016 - 02:05 AM
Rick already on the case! Thanks Andrew
#15 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 16, 2016 - 02:31 AM
Eric and Roger, thanks for your respective comments on the engine saga. Any help will be greatly recieved.
Cheers Andrew
