Broke the hdt1000
26 replies to this topic
#1 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 14, 2016 - 11:03 PM
So got some rock today so I stole dads hdt1000 cause is a beast anywhere bone the cast front axle cradle again. It's been broke a few times.
I need one bad. Who's got one?
  • chieffan and 637Yeoman have said thanks
#2 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted January 14, 2016 - 11:44 PM
Ooops! Sorry I don't have one for you, but I wish you good luck. Maybe make one of the steel ones is a solution, like that guy across the pond did. ( IIRC, he was in Sweden)
  • WrenchinOnIt, chieffan and 637Yeoman have said thanks
#3 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted January 14, 2016 - 11:53 PM
How did it break?
#4 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 15, 2016 - 12:05 AM
Well its been broke twice before. The old man had it welded once. I was twisted up a bit pushing on a rock pile and I heard a pop and then didn't have steering worth a crap.
  • chieffan said thank you
#5 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 15, 2016 - 12:07 AM
Couple pics
#6 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted January 15, 2016 - 04:06 AM
I'd try three of our site sponsors first, Rick Show, Bob Hill, or Joe's Outdoor Power, none on Ebay that I can see right now, probably can be seen as a weak link IMO ,however there are more surviving intact than broken so I don't know, but usually something is the culprit as to why it broke that's outside of the ordinary wear and tear ( ie 2-stage blower).
Edited by WrenchinOnIt, January 15, 2016 - 06:28 AM.
  • blackjackjakexxix and chieffan have said thanks
#7 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted January 15, 2016 - 07:21 AM
Two different versions of bolsters, basically differing axle support pin diameters, later model 23's they went to a larger pin (3/4" I believe ) the early LF models had bushing sleeves in axle for smaller pin, either will work you can bore the old style bolster out, or sleeve the newer axle to fit in an older bolster, have done both and had no problems, if sleeving the axle based on bolster is your choice, McMaster - Carr has the correct size plus longer lengthed ones
Edited by WrenchinOnIt, January 16, 2016 - 03:33 PM.
  • blackjackjakexxix, chieffan and Paulgo have said thanks
#8 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 15, 2016 - 09:52 AM
Ouch!
Hope you can find a new one and be up and running soon.
Did they ever use steel or were all of the ones cast?
#9 Bud W OFFLINE
Bud W
    old member
  • 520 Thanks
  • 407 posts
Posted January 15, 2016 - 10:11 AM
My Dad replaced one on his 1476 (with a front end loader on it) with a torch cut plate and it's still working.
  • WrenchinOnIt said thank you
#10 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 15, 2016 - 01:32 PM
I'll pm you,I have one left,Rick
#11 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 15, 2016 - 02:18 PM
Sent a pm back.
#12 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 15, 2016 - 04:25 PM
Ouch!
All cast,like Kevin said always seemed to be the weak point on them,the 2 stage blowers were always hard on them
#13 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 15, 2016 - 04:41 PM
Had to get the big gun out.
#14 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted January 15, 2016 - 07:20 PM
Nothing like a pair of 51 year old machines to get a job done. 20.25 total hp. 1.75 less than the hdt 1000 by itself
Yeah get some!
#15 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted January 15, 2016 - 07:38 PM
Ummm! Really needed a bigger rig for that heavy work?   Guess this means Bolen's Break when doing hard work, heee!  :D
