Wanted
Three point blade
10 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted January 13, 2016 - 11:41 PM
Anyone selling a Category 0 three point rear blade or box blade? Looking for one of either at least 48" width (covers outside tire width of 45"). Any opportunity considered.
  • chieffan said thank you
#2 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted January 14, 2016 - 05:24 AM
I don't know what you are using the blade on but you may want to consider a 60" so that tracks are covered when you angle the blade.  Get the right blade and you can put cat. 0 pins turned inside.  That's what I always did with my blade when I used it with Power King tractors and the Beav every once in a while.  If you think your tractor could handle a 60" blade, I would recommend it.  I would stick with a 48" box blade though.
  • limebuzz, Alc, wvbuzzmaster and 1 other said thanks
#3 chieffan OFFLINE
  • 7,530 Thanks
  • 5,317 posts
Posted January 14, 2016 - 09:27 AM
Very good point by David Brown.  The blade narrow up fast when you start to angle them. The added sway of the 3 point adds to that also.
  • wvbuzzmaster said thank you
#4 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted January 14, 2016 - 05:27 PM
Right, that's why I said at least 48" wide.
#5 jpswift1 OFFLINE
jpswift1
  • 359 Thanks
  • 343 posts
Posted March 01, 2016 - 12:46 AM
I found a couple of 4 ft box blades in my area and I was wondering how my 1855 Snapper with 120lbs of wheel weights and Goodyear Super Terra Grip ag tires would do.  I know it's a very big tractor, but I feel a bit skeptical that it would work well.  Any thoughts?  Thanks everyone.
#6 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted March 01, 2016 - 12:59 AM
How much are those box blades?
#7 KennyP ONLINE
  • 32,725 Thanks
  • 42,332 posts
Posted March 01, 2016 - 06:01 AM
Might have to do what I did, Casey! Widened a narrow box blade to what I wanted and added the 3-point hitch.
#8 jpswift1 OFFLINE
jpswift1
  • 359 Thanks
  • 343 posts
Posted March 01, 2016 - 07:25 AM
They were $450 and like brand new, but it's still a little expensive.  I heard you could use a 4ft category 1 box blade and just put category 0 pins on it and turn them facing in.  Also, putting bushings through the two lower mounting holes so the bolts for the pins don't work themselves loose.
#9 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted March 01, 2016 - 12:04 PM
I may just give up the hunt for box blades. Those will be kind of useless after the International TD-9 and T-340 dozers get home. :D
#10 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted March 06, 2016 - 09:57 AM
PM sent
#11 MH81 ONLINE
  • 29,220 Thanks
  • 29,417 posts
Posted March 06, 2016 - 05:50 PM
Wha? Td340?
Really?
Does it have a Drott bucket?
