That's very impressive work! The battery decals are a nice touch, I really like those. Thanks for sharing the pics.
MF12 Restoration
#16
OFFLINE
Posted January 14, 2016 - 04:30 PM
- Sawdust and KBuzz have said thanks
#17
OFFLINE
Posted January 14, 2016 - 04:35 PM
Oh, and by the way, do you have a favorite parts source. I am having a heck of a time finding a carb for this thing.
MF-G Tecumseh
#18
OFFLINE
Posted January 14, 2016 - 08:12 PM
Awesome work! I hope I can get my 12 done someday. I agree those battery decals really set it off.
#19
OFFLINE
Posted January 14, 2016 - 08:19 PM
Looks Awesome.
#20
OFFLINE
Posted January 14, 2016 - 09:24 PM
That is SWEET!!! Nice work! Now I wish mine looked that good.
#21
OFFLINE
Posted January 14, 2016 - 09:48 PM
I'll post some replies to questions and comments tomorrow morning when I can use my laptop instead of my phone. I'll also get a couple pics of the exhaust installed and of the grille.
- MH81 and Sawdust have said thanks
#22
OFFLINE
Posted January 15, 2016 - 09:13 AM
Wow, nice job. Will last for years.
Noel
Looking as good as new and lasting for many years was my goal going into this project. I wanted it to have a "WOW" factor with my dad and family when it's complete to show them that we don't just "tinker around" in the shop-actual work and projects do get done!
I also wanted my son to be able to have it for many years into the future to help him remember his Massey Ferguson roots.
Better than showroom , he has every reason to be excited!
Andto you Dad. It's time well spent.
I do see one little thing and to avoid you irritation issues later is the only reason I bring it up.
To the best of my knowledge, the extended gas tank has to be used with the short dipstick, but they used the long dipstick with the deluxe muffler because of being very hard to reach. Might look at that situation and see if there is a resolution.
This tractor didn't originally have the deluxe muffler option and I'm assuming that the dipstick is the correct one for this engine. However, I'm not fully convinced that this is the original engine to it. It is a Tecumseh HH120, just maybe not the factory installed one. To your point, getting at the dipstick with the muffler and gas tank on it is a pain in the you-know-what and we won't be checking the oil level when it's hot!
Nice deluxe muffler and nice work.
I was originally trying to get ahold of a member of this forum that remakes these mufflers and heat shields in polished stainless steel, but was never able to get in touch with him. The original peppershaker muffler was shot anyway, so when I came across this one on eBay and figured I'd better jump at the opportunity to have one.
That's the same thing I thought when I first saw them and had to have a set. Thanks to member DanP for reproducing these and making them available to the rest of us.
MF-G Tecumseh
Honestly, eBay has been a good parts source. Our engine and carb rebuild parts have come from there. Also, our sleeve hitch and deluxe muffler came from there. Just have to do some solid research to make sure what you're buying is actually going to fit when it shows up. Our bearings, seals, belts, etc. have come from our local NAPA and (as much as I don't like to say it) John Deere dealers. JD is a bad word in our family!
- DMAX, limebuzz, Alc and 3 others have said thanks
#24
OFFLINE
Posted January 15, 2016 - 09:54 PM
MF-G Tecumseh
I believe two (or more) of our sponsors has them.
#25
OFFLINE
Posted January 17, 2016 - 12:22 AM
What's the trick to masking off the front wheels to make them two-tone? You also did an amazing job painting the black insert on the grille.
- Sawdust said thank you
#26
OFFLINE
Posted January 17, 2016 - 12:54 AM
I just did an inspection of your work on my 60" monitor (VIZIO TV) and all I can say is EXCELLENT WORKMANSHIP!!
#27
OFFLINE
Posted January 17, 2016 - 06:27 PM
I'm pretty sure your engine may be the original but I read somewhere on this site that when the long gas tank option was purchased you could not get the deluxe muffler and that option would also use a shorter dipstick. The pic is the dipstick for the shorter tank and deluxe muffler. Maybe someone will speak up that has more accurate info.
This is a beautiful build and your craftsmanship and attention to detail is top notch! Thanks for posting it.
DAC
#28
OFFLINE
Posted January 17, 2016 - 07:53 PM
The grille took a fair amount of time to mask off to my satisfaction and I think we used half of a roll of tape!What's the trick to masking off the front wheels to make them two-tone? You also did an amazing job painting the black insert on the grille.
As for the wheels, I used our Cricut machine with some vinyl to make round stickers to use as the defining line.
1) Prep and paint the centers red.
2) After the paint is set up, apply round vinyl decals to the centers and mask off any other areas that we don't want to be silver.
3) Lightly sand the outer rim, prep and paint silver. The paint that I used needed to be clear coated to get the amount of gloss that I wanted.
4) After the silver and clear coat are dry enough, carefully peel up the round vinyl decal and any other masking tape. I had to run a small knife along the vinyl to get a clean break.
- limebuzz, MFDAC and Sawdust have said thanks
#29
OFFLINE
Posted January 17, 2016 - 08:13 PM
Thank you!I just did an inspection of your work on my 60" monitor (VIZIO TV) and all I can say is EXCELLENT WORKMANSHIP!!
Our engine was white with gray shrouding and such. I've been told that the original engines were all gray. We just put it all back together the same way it was when we took it apart. I'd be curious to learn more too. We have a 1971 MF12H parts machine and it definitely doesn't have its original HH120, but has the same dipstick and gas tank combo as this one.I'm pretty sure your engine may be the original but I read somewhere on this site that when the long gas tank option was purchased you could not get the deluxe muffler and that option would also use a shorter dipstick. The pic is the dipstick for the shorter tank and deluxe muffler. Maybe someone will speak up that has more accurate info.
DAC
#30
OFFLINE
Posted January 17, 2016 - 09:03 PM
I think you are right on the engine color, so it probably was a transplant.
Do the Cricut's use standard sign vinyl? You can buy masking vinyl that makes removal a lot easier. Sometimes it's still a good idea to trim with the exacto like you did anyway. I've been cutting vinyl in the same old 24" cutter since 1992.
DAC
