* * * * * 1 votes
Info for sears dozer blade (917.99550) | (Solved)
27 replies to this topic
#16 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 19, 2016 - 01:29 PM
Would it be ok If I was to build a support frame out of 2x4 for the time being? I can easily drill out holes for large bolts.
I think it should be ok. Just make sure that it is tight with NO movement front to rear. Go from the bottom of the plow mount to the rear of the tractor. Again, the front to rear twisting of the front axle needs to be eliminated. Measure twice and cut once.
  • wbakunis said thank you
#17 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 07, 2016 - 05:53 PM
Removed the plow from the ST/10 and snapped a few pictures of the long support bars. Figured I would add them to this post for future reference.
My bars are of the later 2 piece design, but could easily be fabricated as one piece. Bar is 1" outside diameter, 49 3/4" overall length, holes are 5/8", and end stub is also 5/8". I use the last set of holes on my setup. For the bars, 3/4" electrical conduit or 3/4" pipe should be strong enough. Cut off 5/8" bolt with washer and weld to the front. Watch out for welding galvanized, don't breath the fumes. Drill hole for pin.
At the front end, there is a bow of ~1/4".
Hope this helps,
Brian
  • limebuzz, MH81 and wbakunis have said thanks
#18 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted April 07, 2016 - 02:10 PM
I have the original owners manual for this grader blade and it's fairly in depth . I also still have the blade and all the attachments and I'm in the process , probably this fall , of fabricating a plate that will attach to my JD e series tractor ( front weight bracket ) and also the brackets to attach the long stabilizing arms to the rear of the tractor .
If your interested in a copy of this manual you can PM me and we'll work out the details .
#19 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted April 07, 2016 - 04:23 PM
If you can upload it here, folks would be grateful!
#20 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted April 07, 2016 - 05:22 PM
I do really appreciate the thought. I would rather like to see the manual get copied into a PDF format and uploaded onto here like what @KennyP said.
#21 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted April 12, 2016 - 02:50 PM
I wish I could upload or download or PDF a format , but I don't know how to , any help provided and I may give it a whirl , I need to be more knowledgeable about this stuff , I only learned how to send e-mails a year or so ago so I'm pretty far behind the loop . I can fix stuff though so I ain't completely dumb . I would be glad to send this stuff if I knew how . I have complete manuals on the plow , disc , cultivator and grader blade as well as the 74 Sears Suburban tractor .
  • limebuzz and KennyP have said thanks
#22 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted April 12, 2016 - 04:59 PM
You'll need to scan the manuals in to puter language first. That can be intimidating to start with. There is a business that does that, but the name eludes me right now!
#23 mcrile OFFLINE
mcrile
  • 4 Thanks
  • 7 posts
Posted September 01, 2016 - 09:02 PM
I have the engine pulley for that snowthrower. Let me know if you are interested.
#24 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted September 01, 2016 - 10:36 PM
Really? If so, that is incredible. How much you asking for it?
  • mcrile said thank you
#25 mcrile OFFLINE
mcrile
  • 4 Thanks
  • 7 posts
Posted September 02, 2016 - 08:47 AM
http://searstractormanuals.comI have a snow/dozer blade like yours. The angle control lever should attach to rod at bottom of frame and stand up straight. Used rope in hole at top to operate. Also had rope attached to top outside corners of blade to move. This is an early version. Mine is yellow and has 131 prefix. Roper used more than one prefix.
#26 mcrile OFFLINE
mcrile
  • 4 Thanks
  • 7 posts
Posted September 08, 2016 - 11:03 PM
price for pulley is freight.
#27 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted September 09, 2016 - 04:47 PM
Really? This is too good to be true. I'm going to be shooting myself in the foot for this but do you realize how much these pulleys are worth? They go upwards of $100-$150. I would rather pay full price and not be a jerk haha. I cant afford to do that at the moment. Price of freight is no more than $50 if you pack it right. The last time I payed cheapily for shipping body panels, they didn't arrive in great shape.  :D
Edited by wbakunis, September 09, 2016 - 04:53 PM.
#28 mcrile OFFLINE
mcrile
  • 4 Thanks
  • 7 posts
Posted September 10, 2016 - 10:16 PM
I know what they cost. Rather see it used than scrap. Had two at one time, came in a box of spares.
