Super 3 Project
31 replies to this topic
#16 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 14, 2016 - 10:30 PM
Hope these pictures will help if not I can take more attachicon.gifDSCN1992.JPGattachicon.gifDSCN1993.JPGattachicon.gifDSCN1994.JPG
They help a lot. Thank you very much for taking the time to do this. I have a carb rebuild kit on the way and my tank is at the radiator shop being repaired. I tried to weld some holes myself but got in over my head pretty quickly.  I now have an idea on the correct cabling. Ill let you know how it goes.
Pat
#17 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 14, 2016 - 10:50 PM
Really appreciate this thank you.
#18 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 18, 2016 - 09:56 PM
I got my tank back today. Took it to a radiator shop. They were able to solder fill the pin holes then lined the tank with a liquid plastic.
  • Bolens 1000, Alc and Lauber1 have said thanks
#19 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 20, 2016 - 05:42 PM
I could use some advice if you have a minute. I put things back together and your pictures helped. I'm stumped on an issue. I attached the throttle wire to the governor as shown in the photo. Then I connected a carb spring from the governor control lever to the governor shaft. I am not sure on the proper tension here but that isn't my main concern right now.  My main question is the throttle on the carb must connect to something but I don't know what or how? Do you know how this connection is made on a Carter N carb? I attached photos of my carb, governor, and front view.
Thanks  Pat
#20 jabelman OFFLINE
jabelman
  • 2,216 Thanks
  • 1,589 posts
Posted January 20, 2016 - 05:54 PM
I have the diagram I will look it up.
I always use a new spring when I do restorations. you never know over the years if someone tried adjusting the tension or do other odd things
Edited by jabelman, January 20, 2016 - 05:54 PM.
  • Pats said thank you
#21 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted January 20, 2016 - 08:00 PM
I will try to get some better pictures of the linkage from the governor to the throttle shaft . I do know the rod isn't straight but has a bow in it ,
#22 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 20, 2016 - 11:53 PM
Thanks. The carb spring was missing so I used one I had on hand. Not an original for sure.
#23 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 20, 2016 - 11:54 PM
Thank You.
#24 Sugarmaker OFFLINE
Sugarmaker
  • 238 Thanks
  • 181 posts
Posted January 21, 2016 - 08:29 PM
Pat,
Welcome and you are moving right along on the DB! Tires look good! Mine has a Briggs N engine so I cant help you much. I did go to a local hardware store and got 7 feet of throttle cable.
Regards,
 Chris
#25 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted January 21, 2016 - 08:59 PM
How are these pictures of the throttle linkage DSCN1995.JPG DSCN1996.JPG DSCN1998.JPG ?
#26 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 22, 2016 - 05:34 PM
How are these pictures of the throttle linkage attachicon.gifDSCN1995.JPGattachicon.gifDSCN1996.JPGattachicon.gifDSCN1998.JPG ?
Thanks.
Sorry I didn't notice it sooner but our carbs are different. The bent wire shown in the photo attached to governor shaft, does that connect to your carb at the throttle?
Pat
#27 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted January 22, 2016 - 09:04 PM
Connects on the bottom of the throttle
#28 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 22, 2016 - 10:55 PM
Thanks.
#29 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted January 23, 2016 - 06:55 AM
I can't remember if all the linkage is there on the other DB Super Power , I won't be able to get to look until the middle of next week but will check
#30 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 23, 2016 - 07:49 AM
Thank you.
