Super 3 Project
31 replies to this topic
#1 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 13, 2016 - 11:10 AM
Morning Gentlemen and Ladies
I am new to this forum. I just acquired a Super 3 from a friend who used it as yard art. It has the Continental AU85, with the Carter N carb.  I would like to get it running. It came with a snow plow, disc, plow, and tiller. The engine is not frozen. It is missing reverse block and spring components and the carburetor and governor aren't hooked up and I'm not sure on the correct assembly of cables. I took off the tank and it is rusted with many pin holes. The carb was frozen so I took it apart and plan to find a rebuild kit. The plan is to figure out a fuel tank, rebuild thee carb, figure out the fuel, magneto cabling and try to fire it up. I will search the forum for part suppliers and advice from those who have been through this. I have some experience rebuilding a Farmall Cub, but this is my first DB.
Thanks
Pat
  • Gtractor, Alc, hamman and 6 others have said thanks
#2 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted January 13, 2016 - 11:19 AM
Hello Welcome to GTT
Sounds like you saved this machine from a slow painful death!
There are alot of knowledgeable guys here that should be able to help you, I should have the carb kits instock for that carb if you need one
Sit back an enjoy the site :wave:
  • Lauber1, chieffan, 637Yeoman and 1 other said thanks
#3 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted January 13, 2016 - 11:44 AM
Welcome to GTTalk !   I have 2  DB Super Powers  with Continental engines , let me know if you any pictures
  • Bolens 1000, chieffan and Pats have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted January 13, 2016 - 04:26 PM
:welcometogttalk:
  • Pats said thank you
#5 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted January 13, 2016 - 06:06 PM
I too have a db walk basically that was in the same condition. I am not a fan of walk behinds but I always liked the look. I am about 1/2 way through restoring it.
fortunately thousands were made and they hold more value in parts so ebay is your best bet. I picked up everything I needed there. I paid 15 bucks for a mint gas tank.
I would pull the tires off a clean up the inside of the rims and brush paint rustoleum. most were loaded with calcium.
they are pretty simple parts diagrams are easily found here on elsewhere on line
#6 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 13, 2016 - 08:06 PM
Thanks. Ill check out the web site. Pat
#7 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 13, 2016 - 08:28 PM
 I would love a couple of pictures if you can. One showing the correct cable hook up for the Carb and the Governor. A second showing your reverse drive hubs if you have it. Here is what I have and I know I am missing components.
Thanks
Pat
  • Bolens 1000 and Lauber1 have said thanks
#8 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted January 13, 2016 - 08:42 PM
Ill have to take some of the carb . Can't help with the reverse parts.
#9 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 13, 2016 - 10:10 PM
Thank you for the web site help.
  • Bolens 1000 said thank you
#10 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 13, 2016 - 11:06 PM
Thanks
Pat
your missing the shift blocks, looks like you only have one left. there was a guy in OH making replacements at one time. they rarly show up on ebay.
#11 IWLBCNU OFFLINE
IWLBCNU
  • 123 Thanks
  • 160 posts
Posted January 14, 2016 - 06:31 AM
WOW, and no one noticed the RARE part he did get with the tractor????? That tractor had a tiller at some point! It you don't need the wheel dog, I would like to buy it from you!
I have that model tractor that is pretty original. Also the manuals are online.
  • Alc and Pats have said thanks
#12 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted January 14, 2016 - 06:44 AM
I saw that funny looking pulley on the axle but had not idea what it was for , thanks
#13 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 14, 2016 - 02:10 PM
#14 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted January 14, 2016 - 07:35 PM
Hope these pictures will help if not I can take more DSCN1992.JPG DSCN1993.JPG DSCN1994.JPG
  • Bolens 1000, DougT and Pats have said thanks
#15 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 14, 2016 - 10:25 PM
So that's what that dang thing is. Couldn't figure out how to disengage it and the tractor wouldn't roll so I removed it for now so I could move the tractor around (that was no easy project, stuck pretty good). Yes it came with a tiller, a moldboard plow, a snow plow and a disc harrow. No plans to sell anything yet until I figure out what I need and what I don't, but I will certainly give you a shout if/when I do. Thank you.
