1886 Tillers
18 replies to this topic
#16 wilberj ONLINE
wilberj
  • 4,469 Thanks
  • 5,328 posts
Posted February 01, 2016 - 11:33 PM
So, I finally re-connected with the owner of the tiller. Turns out the serial number is worn off. I got the two attached pictures of it. Can anyone here tell which model it is?
That is a tube frame tiller that wont fit your tractor.
  • JDub said thank you
#17 JDub OFFLINE
JDub
  • 54 Thanks
  • 43 posts
Posted February 02, 2016 - 12:23 AM
Thanks, Wilber. Your expertise is much appreciated.
  • wilberj said thank you
#18 JDub OFFLINE
JDub
  • 54 Thanks
  • 43 posts
Posted February 02, 2016 - 12:24 AM
Sounds like this is a no-go for my unit. So, If anyone is interested in a tube frame tiller located in southwestern Idaho, let me know and I'll put you in touch with the seller.
#19 OldBuzzard ONLINE
OldBuzzard
  • 6,644 Thanks
  • 4,669 posts
Posted February 02, 2016 - 06:04 AM
I know it wont how it is but is it poss to change brackets to suit 1886 rear end?
Do you also need longer drive shaft??
Even if you got it to mount, and got the longer driveshaft, it still wouldn't work.
The tube frame PTO runs at 3600 RPM at full throttle, and the large frame PTO only runs at 2000 RPM.
  • Bolens800uk said thank you
