Le Roi engine
12 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 12, 2016 - 11:18 PM
Another hobby of mine besides GTs is old engines, mostly Briggs and Stratton and Wisconsin, the only oddball is a two cylinder Le Roi engine I picked up last summer and haven't messed with.  This picture is of a similar one(no pictures of mine as it's under a tarp and I don't feel like chasing the tarp into the next county if I uncover it), would like any info I can get on these.
  • Alc, Cvans, tiretrx and 4 others have said thanks
#2 Alc ONLINE
  • 7,357 Thanks
  • 7,638 posts
Posted January 13, 2016 - 06:12 AM
Never heard of that brand , do you have any info about it ?
#3 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,332 Thanks
  • 10,293 posts
Posted January 13, 2016 - 08:00 AM
LeRoi made air compressors.
#4 Cvans ONLINE
  • 7,476 Thanks
  • 6,472 posts
Posted January 13, 2016 - 10:51 AM
Interesting. Looks like 1/2 a Model T engine.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,149 Thanks
  • 5,101 posts
Posted January 13, 2016 - 11:57 AM
LeRoi made a lot of engines for different uses. they were based in Milwaukee WI.  Several trucks and tractors used them. The Centaur tractor used LeRoi engines starting in 1926 and later became a division of LeRoi in the 40s. I believe the compressors came later. They built a tractor called the Tractair that was a 4 cyl engine and 2 cyl compressor all in the same block. Those were built at the Centaur plant in Greenwich OH. That part of the company was sold off to Westinghouse Air Brake Co in the mid 50s. The engine side was sold off to Waukeshaw (sp?) compresors are still being built under the LeRoi name in Sidney OH. LeRoi stood for "the king" in French.
  • LilysDad and adamjd200 have said thanks
#6 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 13, 2016 - 01:14 PM
I've seen the engines around, but haven't managed to get one until now, I also knew about the compressors and had heard brief mention of the tractor, has anyone ever seen a Tractair in person?
#7 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 27, 2016 - 11:45 PM
I've since looked at the tag on mine, I can make out the serial number but can't tell what model it is, if I post pictures can anyone here help with a positive ID?
#8 DougT ONLINE
DougT
    Dog Approved
  • 7,149 Thanks
  • 5,101 posts
Posted February 01, 2016 - 03:33 PM
I have a rough one out back in the weeds.
I'm thinking a model M or one of it's variants. Some of Leroi's models make no sense and I've always thought their parts inventory had to be a nightmare.
  • adamjd200 said thank you
#9 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted April 06, 2016 - 03:44 PM
Finally managed to get a couple pics, need to find a way to hold the crank better.(see second pic)
#10 DougT ONLINE
DougT
    Dog Approved
  • 7,149 Thanks
  • 5,101 posts
Posted April 07, 2016 - 08:20 PM
What does your crank look like? Can't see much there in the picture.
#11 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted April 08, 2016 - 10:14 AM
Just the standard crank, like this one,
end of crankshaft is made to fit, was turning it over with a Farmall C crank but it's too long and I don't want to cut it as they aren't easy to find anymore.
#12 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 369 Thanks
  • 507 posts
Posted April 08, 2016 - 11:37 AM
Hi just a quistion but do you think you can make a genorater out of a 76 chevy 350
#13 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted April 08, 2016 - 07:24 PM
Uh, if you can find a way to attach it then yes, try to stay away from generators myself.
  • pick-to-stone said thank you
