Got my SpeeCo Quick Hitch
9 replies to this topic
#1 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted January 12, 2016 - 07:13 PM
Just picked this up today, I got it stuck on but I haven't had time to put on a implement.  The first disappointing thing was I broke one of the grips on the lever before I even got it out of the pickup, the other grip is about to break. They should of used a rubber type of a grip instead of a harder plastic grip. But other then that, the hitch looks nice and heavy. Can't wait to get my box blade stuck on.
Edited by BTS, January 12, 2016 - 10:49 PM.
  • olcowhand, Gtractor, wvbuzzmaster and 9 others have said thanks
#2 Genem OFFLINE
Genem
  • 83 Thanks
  • 56 posts
Posted January 12, 2016 - 09:02 PM
I would think you will like it. I have had one for many years. Would not be without it. Gene
  • BTS said thank you
#3 FrozenInTime OFFLINE
FrozenInTime
  • 755 Thanks
  • 442 posts
Posted January 12, 2016 - 11:05 PM
Looks good.  I'm thinking pretty hard about getting one.
#4 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted January 12, 2016 - 11:18 PM
I'm already liking it and I haven't even used it yet :rolling:
  • chris m said thank you
#5 KennyP ONLINE
  • 52500 Thanks
  • 53094 posts
Posted January 13, 2016 - 05:18 AM
Looks like a neat tool! Someone made one of those for a GT some time back.
#6 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted January 13, 2016 - 07:20 AM
I remember seeing that. It was a Cat 0 sized one and I think it was for a JD GT if I recall.
  • KennyP and BTS have said thanks
#7 KennyP ONLINE
  • 52500 Thanks
  • 53094 posts
Posted January 13, 2016 - 07:21 AM
I don't remember where I saw it, though! It was a scaled down version.
#8 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted January 13, 2016 - 07:25 AM
I always wanted to build one, but I figured it wouldn't turn out as good as a factory built one. I then got the gift certificate and thought why not. Hoping to play with it today if all goes well
#9 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted January 14, 2016 - 11:04 PM
Finally got a little work done on the Quick hitch and box blade. I need to goof with the top link pin on the box blade, it's a little to low so the box blade hangs on the top link hook and doesn't reach the bottom hooks. For now I took off the top link hook and used the U bracket thingy that came with the hitch. I got it all hooked up and started doing much needed box blade work on the road and driveway. I made one pass down the road to the end of our property (aprox 200ft). I went to turn around and noticed the tractor was sliding around and didn't want to turn. I thought it was because of the road was a little muddy in the shade but I quickly realized the front tire was flat. The bead was broke on one side and the tire was filled with mud. So I picked the front of the tractor off the ground with the loader and limped it back to the front yard. I need to do a little bit of grass work now but at least the tractor is at the house.
I got the front wheel pulled off and I got the tire removed. by then it was about dark so I am now waiting for the rim and tire to dry so I can knock the mud off. Hopefully I can get it all patched up tomorrow and get this box blading done before it gets to cold and freezes.
  • wvbuzzmaster said thank you
#10 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted January 15, 2016 - 12:03 AM
Nice setup. Glad you had a little fun before your tire decided to make you suffer.
