Massey rear blade
40 replies to this topic
#1 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted January 12, 2016 - 01:53 PM
I built a Massey 10 a few years ago with a narrow front end and a 3 point. Now I want to build a replica of a MF 61 rear blade. I have gathered up a few of the parts and have started on the rear pivot. I need to know what is the distance between where the rear lift arms hook up to the lift pins on the blade. I don't have anywhere I can go measure a cat 0 implement.
Also what is the height from the lift pins to the top link?
  • limebuzz, 637Yeoman, antonioco18 and 1 other said thanks
#2 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted January 12, 2016 - 02:21 PM
Usually Cat 0 has a 20" spread and 12" up to the top link.
  • limebuzz, DanP and 637Yeoman have said thanks
#3 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted January 13, 2016 - 09:30 AM
Thanks for the info and my mistake it is a MF 21 instead of a 61
#4 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted January 20, 2016 - 01:37 PM
IMG_1863.JPG I got the back brace bent for the blade now I have to get it attached and figure out the bottom brace. The spindle is the part the blade turns on.
  • MolonLabe said thank you
#5 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted January 20, 2016 - 11:09 PM
I'm guessing that that is a 1" spindle. You may find that it is a bit too light for that task. The MF10/12 tractors can put a serious pull on the bottom edge of a back blade if it hooks up with a rock or root. Leverage will do the rest.
When I had a FEL on my 12H, it had enough rear axle torque to jackknife the tractor frame and break the weld on the frame splice when the bucket stopped in a pile of dirt. I can easily visualize that spindle getting bent if you hook something solid at speed. The tractor is a 675 lb sledge hammer. That's over 2900 pound feet of force applied to the cutting edge at a 3 mph impact. The weight of any applied ballast plus the operator increases that force load. The rear axle torque also adds.
Making that pivot too strong is never a problem. Whole different ball game if it's too light!
Edited by TUDOR, January 20, 2016 - 11:28 PM.
  • limebuzz, MH81 and DanP have said thanks
#6 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted January 21, 2016 - 11:59 AM
The main shaft is 1 1/4 and the one that is on the Brinly blade was 1  or 1 1/4 . I doubt  if I will use this much as I don't use the Massey I build that it will fit on. It is more for show and the blade is just to see if I can duplicate the real thing. If I was going to use it I would have beefed up the mounting system. My concern is that the blade will be to heavy for my lifting motor to lift it.
This the tractor I am making it for.
#7 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted January 24, 2016 - 06:42 PM
I welded up the rear frame today, now I have to get the center pivot made and attached.
#8 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted February 07, 2016 - 01:25 PM
I welded the frame to the rear of the blade this weekend. Now I have to make the adjusting plate, then the part that holds the dog for the adjuster. Anybody know how to drill a square hole?
#9 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted February 08, 2016 - 07:44 AM
With a square bit?
#10 MH81 OFFLINE
Posted February 08, 2016 - 07:58 AM
Round bits and lots of filing.
#11 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted February 08, 2016 - 08:15 AM
Item 28 is a square dog that fits in a cast iron part under the back end and is used as the locking mechanism to adjust the angle of the blade. Since it is cast I don't think it will be that hard to file square. I could buy a $200.00 broach and cut it but not sure I would ever use it again.
#12 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted February 08, 2016 - 08:26 AM
That's good. I really don't like loaning out my square bit!  :smilewink:
#13 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted February 08, 2016 - 08:57 AM
I could buy one of these.
www.youtube.com/watch?v=ALiqAXiTQBg
#14 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted February 08, 2016 - 08:50 PM
I made the spindle washer for the upper adjustment plate tonight. Now I have to make the plate with the notches in it.
#15 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted February 10, 2016 - 10:07 AM
I laid out the adjusting plate last night. Had to go way back and remember my geometry days to figure it out. But it worked and I got the holes drilled now I just have to spend some time at the band saw to cut the curve and the notches out.
