Berco blower on the Ht20
48 replies to this topic
#1 hammerdwn20 OFFLINE
hammerdwn20
  • 127 Thanks
  • 283 posts
Posted January 10, 2016 - 11:03 AM
So i picked up a berco 48" snowblower last weekend and plan on putting it on the HT20 with the 2 cylinder kubota diesel.
20160103_122131.jpg  also 48" with the side wings
Replacing this single stage with
comparison
Using the mounting frame off of a blower that the auger is in bad shape on
I stripped the belt drive system off the berco. The input of the blower is opposite of the pto on the bolens. The bolens also spins at 2000rpm which would give a tip speed on the second stage of the blower of 7588ft/min. about double what it should be even if it had the power to turn it. To solve this issue i found a reducing gearbox made by Hub City. The Model 22 with a 2 to 1 ratio and with it being a gear driving another gear it will reverse the rotation as well.
  • LPBolens, blackjackjakexxix, KennyP and 7 others have said thanks
#2 KennyP ONLINE
  • 53245 Thanks
  • 53335 posts
Posted January 10, 2016 - 11:25 AM
This should be fun to watch!
  • MyBolens1053 said thank you
#3 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted January 10, 2016 - 12:11 PM
I'll be watching. Thanks for sharing.
  • 637Yeoman said thank you
#4 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted January 10, 2016 - 01:25 PM
Lets see some pics of the diesel you stuffed in the HT20,
#5 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted January 10, 2016 - 01:46 PM
I was thinking of doing a two stage set up for my 1050 and g12. Already have the big 2 stage for the ht20. But a smaller one would be nice with small snow falls. Looking forward to seeing progress.
#6 BolensChrisUK OFFLINE
BolensChrisUK
  • 603 Thanks
  • 263 posts
Posted January 10, 2016 - 02:48 PM
Yes please also. Good to see how to repower them when the poor old kohlers die
#7 hammerdwn20 OFFLINE
hammerdwn20
  • 127 Thanks
  • 283 posts
Posted January 10, 2016 - 03:59 PM
the ht20 repower is in the diesel  conversion section of the forum. I also have the 1250 conversion up to where i stopped. Its been some years now that ive worked on the 1250
#8 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted January 10, 2016 - 05:30 PM
I have thought about building a 2 stage blower for my tube frame Bolens as well. I was thinking of converting a walkbehind blower, but I would need a gearbox like the one you bought to make it work. I looked up their website and found the specs on it, but I did not see a price. If you don't mind me asking, how much did the gearbox cost?
Jim
#9 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted January 10, 2016 - 07:05 PM
I this gear box going to be enough?  ie, 875 rpm out, and max input hp 1.07.
This sounds a bit light to drive a 2 stage 48" blower.
Dan
"Standard Duty, 1750 Input RPM, 875 Nominal Output RPM, Bore Dia. 5/8 In., 2:1 Nominal Ratio, Max. Input HP 1.07, Max. Output Torque 77.2 in.-lb."
#10 hammerdwn20 OFFLINE
hammerdwn20
  • 127 Thanks
  • 283 posts
Posted January 10, 2016 - 07:24 PM
Dan
.-lb."
There are about 15 different model 22 gearboxes. The one you listed is 5/8 bore. Definitely not for a snowblower. The one I got is 1" shaft size and I believe 17hp rated. My engine is around 14hp.
Edited by hammerdwn20, January 10, 2016 - 08:00 PM.
#11 hammerdwn20 OFFLINE
hammerdwn20
  • 127 Thanks
  • 283 posts
Posted January 10, 2016 - 07:27 PM
Jim
380 plus shipping. More than I'd like to have spent but I feel it will be worth it in the end for a clean and trouble free installation.
#12 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted January 10, 2016 - 11:30 PM
That sounds better, I just opened the link and read the specs.
There seem to be lots of old Bolens blowers around, at least here.  Is it worth it to convert one?
And from answers here, it seems they are available in drives in both directions.
Dan
  • Paulgo said thank you
#13 Husky OFFLINE
Husky
  • 1510 Thanks
  • 1202 posts
Posted January 11, 2016 - 07:42 AM
Wow very interesting. I've got a RAD 44" two stage on my DGT 1700 and would love to be able to put similar onto my 1886. This is going to be a good thread to watch. Best of luck this.
#14 BolensChrisUK OFFLINE
BolensChrisUK
  • 603 Thanks
  • 263 posts
Posted January 11, 2016 - 04:12 PM
Dan
Wish there was more blowers in the UK
I only know of 2. None of which I own :shoot2:
#15 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 11, 2016 - 05:12 PM
Let me guess Iain and Dave?
