Holy heat sink batman!
11 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,164 Thanks
  • 4,279 posts
Posted January 07, 2016 - 09:52 PM
Just upgraded one of my Linux machines that sounded like a jet taking of when using it.
Scythe big shriken rev 2
  • chieffan said thank you
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,189 Thanks
  • 5,666 posts
Posted January 08, 2016 - 04:46 AM
YIKES!!
That thing will make your finger into sausage!
  • Trav1s and chieffan have said thanks
#3 KennyP ONLINE
  • 37,412 Thanks
  • 45,460 posts
Posted January 08, 2016 - 05:36 AM
How many KW/h does it use?
  • MH81, Trav1s and chieffan have said thanks
#4 MH81 OFFLINE
Posted January 08, 2016 - 07:38 AM
From the packaging:
1 if you want to blow the dust out of it, all you have to do is turn it on
2 guaranteed not to overheat unless its on fire.
  • Trav1s, HDWildBill, WNYTractorTinkerer and 1 other said thanks
#5 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted January 08, 2016 - 08:04 AM
"For use in PC or radiator unit for water cooled engine."
  • KennyP, Trav1s, HDWildBill and 2 others have said thanks
#6 Trav1s ONLINE
Trav1s
  • 3,164 Thanks
  • 4,279 posts
Funny thing is that with good case ventilation the fan only runs between 500 and 800 RPMs.  Maxed out it runs 1800-1900 RPMs.  It is about 6" square and is about 3/8" thick and is installed on an AMD Phenom Quad core processor.
Edited by Trav1s, January 08, 2016 - 08:05 AM.
  • olcowhand, KennyP and chieffan have said thanks
#7 JDBrian OFFLINE
  • 9,601 Thanks
Posted January 08, 2016 - 09:17 AM
Speed = power consumption. Power consumption= heat
Modern computers are a lot more efficient than the old ones but are so much faster that heat is still a big issue.
#8 lyall ONLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted January 08, 2016 - 04:58 PM
that should keep the cpu cool.
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted January 08, 2016 - 05:11 PM
What am I looking at, a Toyota?
#10 Trav1s ONLINE
Trav1s
  • 3,164 Thanks
  • 4,279 posts
Posted January 09, 2016 - 12:32 PM
Nah, a better way to say it is this:  The old heatsink was like a Kohler k161 trying to turn a three-blade 48" deck in 12" of grass.  The new one is a Kohler k341 doing the same work.  :D
  • LilysDad said thank you
#11 OldBuzzard OFFLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted January 09, 2016 - 07:19 PM
An HSF :rolling:
I haven't use one of those in ANY of my systems since 2002 :D :D :D
That's when I started water cooling with a Koolance Exos system.
That cooled a couple of systems, and I upgraded to the Exos 2.
At one point I was also cooling an ATI 3870 X2 with it along with the CPU
After a couple of years the pump failed so I went with the Corsair units.
I'm currently using an H80i GT. and it keeps my Phenom II x6 1080T (overclocked to 3.8GHz) under 50C when gaming.
I see no reason to ever going back to air cooling when the new AIO units are so easy to install.
  • Trav1s and HDWildBill have said thanks
#12 Trav1s ONLINE
Trav1s
  • 3,164 Thanks
  • 4,279 posts
Posted January 09, 2016 - 09:17 PM
Well, I am working with a hand-me-down system and trying to keep it cheap.  I will continue with my Old School HSF and warm my work space in the basement with the heat from the old Phenom processor.
:D  :D  :D  :D  :D
Edited by Trav1s, January 09, 2016 - 09:18 PM.
