Finally back and The Bolens question of the week ...
13 replies to this topic
#1 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted January 07, 2016 - 01:21 PM
Hello all,
Been a while since I have trekked over here. Quad bypass and health has had me set back a bit and still not 100% but life goes on.
So, I had unfinished motor details on my 1053. Trans went out on the 850. My thought at this point is to move the good S8D over on to the 1053 until I can fix the TRA-10D.
So I ask this ... will the pulley from the S8D fit onto the TRA-10D ? Both have the same wiring, ignition switch, etc.
Happy winter to all.
  • WrenchinOnIt, boyscout862, propane1 and 1 other said thanks
#2 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted January 07, 2016 - 01:45 PM
I hope your feeling better, check with Dr. Bolens 1000 for the answer he has big Bolens medicine
  • boyscout862, MyBolens1053 and 637Yeoman have said thanks
#3 boyscout862 OFFLINE
  • 15265 Thanks
  • 10024 posts
Posted January 07, 2016 - 01:59 PM
Welcome back. I hope that you heal quickly but, don't push it. Take it easy and take care of yourself. Good Luck, Rick
  • MyBolens1053 said thank you
#4 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted January 07, 2016 - 02:56 PM
I can't remember if the shaft sizes are the same but another thing to consider will be the belt fitment, I don't think the S8D and TRA engines are the same physical size. You may need to adapt custom belts.
  • MyBolens1053 and 637Yeoman have said thanks
#5 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 07, 2016 - 04:04 PM
Welcome Back!
Besides the differences in HP you'll have to swap over the engine pulley's as the S8D is going to have the wrong sheaves on it, the 1050 one used dual drive belts on the Drive and PTO
Pulleys will change over no problem
  • Alc, WrenchinOnIt and MyBolens1053 have said thanks
#6 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 07, 2016 - 04:08 PM
I belive the shaft size is the same,so you may have to use the engine pulley from the other engine,I don't think the belt grooves will line up from the 8 hp pulley
  • WrenchinOnIt and MyBolens1053 have said thanks
#7 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 07, 2016 - 04:10 PM
Welcome Back!
Sorry Brian,must have typing reply back the same time as you were responding
#8 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted January 07, 2016 - 09:13 PM
Thanks for all of the replies, guys. Motors have been pulled and pulleys are swapped. The S8D now sits on the 1053 and I will be measuring from the bottom of the motor casing to the center of the crankshaft extension of each to be certain a custom belt fitting is not required.
Thanks for the tip to check this, chubien.  :thumbs:
#9 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 07, 2016 - 09:34 PM
The engines will sit the exact same height and take OEM size belts :thumbs:
#10 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted January 08, 2016 - 01:02 AM
It sure does. I did learn one thing. Before securing the pulley in place on the crankshaft extension leave it back somewhat and tap it in place to align with the transmission pulleys below. Otherwise, you will be pulling the motor again to pull it out enough to align it (like I did  :wallbanging:  ).
I hope my lesson will save another the time. :smilewink:
Edited by MyBolens1053, January 08, 2016 - 01:03 AM.
  • WrenchinOnIt said thank you
#11 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted January 08, 2016 - 12:13 PM
I'm happy that the swap over works. Best of luck with your health that comes first.
#12 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted January 25, 2016 - 06:45 PM
Well ,went well with the swap. I did end up swapping carbs and intake manifold from the TRA-10D to the S8D. Intake on the blocks are the same bolting pattern.
With new belts on, fluids changed or topped off this machine was no match for what Mother Nature just dumped on us. Not with a snowplow.
Between my shoveling, my neighbor's snow blower and the owner of Arden Tractor Center (John Deere) using a new Deere with a 48" snow thrower I was finally able to get some ride time to help with some cleanup and give the 1053 a workout.
Here's a few from the fixing stage
Now to plan the 10HP rebuild in Spring AND snow thrower resurrection.
  • WrenchinOnIt, 29 Chev and Paulgo have said thanks
#13 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted January 25, 2016 - 08:07 PM
How does it run with with the L63 carb? There was another post about someone doing this swap and claims it runs flawless. This being the case I may consider trying it on some of mine as a have a spare L63.
#14 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted January 27, 2016 - 11:47 PM
I started with setting the carb like instructed in the repair manual for a TRA-10D motor. One and a half turns out from close for the bottom screw. Can't remember the top screw next to the venturi. Once I got it running and warmed, finalized the adjustments, It ran very well. Had a hiccup at full throttle (surging) but backed off enough until it smoothed out.
I'll wait until Spring, when I can mount the mower deck, to adjust it again when I can put a load on it with the PTO.
