Anyone familiar with this?
17 replies to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted January 06, 2016 - 02:31 PM
I have had this all summer but just recently got it up and running and it works very well.This company has been making these since the flat head Ford and I think this one is only slightly newer.
  • hamman said thank you
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 06, 2016 - 02:41 PM
That right there is an engine.  Anything else you want to know?
  • Alc, KennyP, Username and 3 others have said thanks
#3 DougT OFFLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Looks like it says smith on the manifold. I take it must be a Gordon Smith compressor? I have one built from a model A Ford engine but its in sad shape. Built in Tennessee if I remember right.
  • Alc, KennyP and Username have said thanks
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted January 06, 2016 - 02:44 PM
Actually you are only half right but that is still above your average. :D
  • oldedeeres said thank you
#5 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted January 06, 2016 - 02:45 PM
Yes you are correct.Are you going to restore it?
#6 DougT OFFLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted January 06, 2016 - 02:58 PM
I doubt it. It's not real high on the priority list. The reed valves on the compressor were just a solid chunk of rust. It would be more likely to get used as a core for a model A. The conversion doesn't ruin the block to where it couldn't go back as an engine.
  • Username said thank you
#7 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
It's half engine and half compressor! Cool stuff!
  • Username and boyscout862 have said thanks
#8 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 06, 2016 - 03:00 PM
You're right!  I didn't think I did that good.  Oh happy day...
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 06, 2016 - 05:04 PM
  I saw one yrs ago that had a Ford 302, one bank engine the other bank compressor.
                                                Mike
  • MH81, Alc and Username have said thanks
#10 MH81 OFFLINE
Posted January 06, 2016 - 05:15 PM
                                                Mike
My friends dad in HS had one.
1" air line.
Absolute beasts.
#11 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted January 06, 2016 - 05:25 PM
                                                Mike
A good friend of mine has one with a 302 and he uses it for his hole hawg and road boring.They also made a 460 version.
#12 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted January 06, 2016 - 05:28 PM
1" air line.
Absolute beasts.
This one is probably about as small as they make and it's 75 cfm as near as I can tell.You would never think it would even run on half the cylinders let along compress air.This one has a Farmall A carb and it seems just about right for it.
#13 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 13,910 Thanks
  • 10,060 posts
Posted January 06, 2016 - 06:25 PM
1" air line.
Absolute beasts.
Which dad did he have in GS?
#14 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted January 06, 2016 - 07:56 PM
If I remember correctly, one bank of 4 cylinders "ran" and the other bank of 4 cylinders made up the air compressor.
  • MH81 and Username have said thanks
#15 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted January 06, 2016 - 09:24 PM
There used to be a crew here in Newton who specialized in rebuilding commercial
and industrial air compressors. if you hooked up with an outfit like that you might be surprised to find
Replacement reed valves available. When I worked in the maintenece department at the factory, we replaced 3 huge piston compressors with 1 huge compressor (Gardener Denver I think) it was a very large Roots Screw type compressor( like the old GMC Blowers)I do not rember how big the electric motor that ran it was.
