Allis Chalmers big 10
5 replies to this topic
#1 bolensqt17 OFFLINE
  • 27 Thanks
  • 21 posts
Posted January 05, 2016 - 04:58 PM
I have a opportunity to buy a Allis Chalmers big 10 and a Allis Chalmers b-10. I have never owned a Allis so as crazy as it might sound what is the difference between the two?
  • classic said thank you
#2 wbakunis OFFLINE
  • 219 Thanks
  • 190 posts
Posted January 05, 2016 - 05:05 PM
The big ten I believe has a 10hp motor instead of the b10 having a 9HP. Everything else should still be the same as each other. I personally would buy both if I had that opportunity and restore them.
Edited by wbakunis, January 05, 2016 - 05:07 PM.
  • boyscout862, bolensqt17 and 637Yeoman have said thanks
#3 bolensqt17 OFFLINE
  • 27 Thanks
  • 21 posts
Posted January 05, 2016 - 05:12 PM
That's kinda what I figured. Talked to the guy who owns them and were going to look at them this weekend. Thanks for the info
#4 petrj6 OFFLINE
  • 4,083 Thanks
  • 2,369 posts
   Great machines but not horribly valuable unless they are in great shape, you will love them.
  • boyscout862, bolensqt17 and wbakunis have said thanks
#5 boyscout862 OFFLINE
  • 13,144 Thanks
  • 9,266 posts
Posted January 05, 2016 - 05:52 PM
They are great machines and like Bolens, there are alot of attachments for them. I have an early B10 that came with a 9hp engine, a Big Ten that has a 10hp engine and a late B10 with a 10hp engine. Check out www.simpletractors.com to learn more about them. I have about 10 Bolens and about 10 AC/Simplicity tractors. The ACs are more responsive to steering and do a nicer lawn mowing. The Bolens are better pullers and change attachments easier. Both are great tractors. The AC/Simplicities seem to be lower priced. I bought a 10hp Simplicity 3310 with mower, plow, and chains for $200 two years ago. It ran but was filthy. The headlights even work.  Have fun with them. Good Luck, Rick
Edited by boyscout862, January 05, 2016 - 05:53 PM.
  • jpackard56, bolensqt17 and classic have said thanks
#6 classic ONLINE
  • 5,322 Thanks
  • 2,263 posts
Posted January 05, 2016 - 06:08 PM
There are many differences between the 9HP and 10hp engines. The 9hp being the Briggs model 23D and the 10hp being the Briggs model 243431. These two engines have different blocks, heads,cranks, rods, pistons, rings, wrist pins, flywheels, coils, carburetors, intake manifolds, among other things. Just keep this in mind if you need to buy any engine parts. Both engines are very durable and have plenty of power. I use my Big Ten often and it's very reliable, but has a 16hp Briggs on it. I have a 243431 10HP engine that I rebuilt for a future Big Ten restoration.
  • drbish, jpackard56, boyscout862 and 3 others have said thanks
