Welding on a garden tractor ?
welding
13 replies to this topic
#1 MiCarl ONLINE
MiCarl
  • 2,016 Thanks
  • 1,049 posts
Posted January 05, 2016 - 09:31 AM
I've got the shaft made for the mule drive on my Speedex with a Deere deck project.  I clamped the shaft onto the sub frame and measured for a belt - which I will get today.  Assuming everything looks good with the belt in place I'll be ready to weld the shaft to the sub frame.
The shaft needs to just clear the front axle pivot, so it needs to be placed fairly precisely.  Ideally I'd tack it down with the sub frame still on the tractor rather than risk it shifting when I pull the sub frame off.  I'll be welding with a stick welder.
In the motorcycle world, where I'm most familiar, there is great concern about damaging ignition modules when welding on a motorcycle.  I've never bought in to that - I don't see how if you get a good ground reasonably near where working it could damage the electronics.  Still, I generally disconnect them just to be safe.
The Vanguard twin on my Speedex seems to have the ignition module buried under the shroud, so not quick to disconnect.
What kind of experience do you folks have?  If I ground at the sub frame can I safely tack the shaft in place?
  • chieffan and vewatodo have said thanks
#2 shorty ONLINE
shorty
  • 5,475 Thanks
  • 5,258 posts
Posted January 05, 2016 - 09:38 AM
Disconnect the battery.
  • HDWildBill and chieffan have said thanks
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 05, 2016 - 09:40 AM
  Just disconnect the ground cable from the batt.
                                             Mike
#4 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted January 05, 2016 - 11:44 AM
I disconnect my regulator, along with the battery.
Noel
  • chieffan said thank you
#5 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted January 05, 2016 - 11:50 AM
I may not be the safest character, but I just weld!  Never had an issue with any electronics.  Like you said, I place ground near weld and go.
  • ENafziger, propane1 and chieffan have said thanks
#6 Cvans OFFLINE
  • 6,640 Thanks
  • 6,126 posts
Posted January 05, 2016 - 11:57 AM
Keep your ground as close to where your welding as possible. Don't let the current pass through bearings or pitting may occur. Other than that I weld as normal with no problems so far.
  • olcowhand, propane1 and chieffan have said thanks
#7 tater195 ONLINE
tater195
  • 2,194 Thanks
  • 1,410 posts
Posted January 05, 2016 - 02:35 PM
The old style battery chargers are harder on the newer atv ECM's than anything. I dont own any new enough GTs to have the fancy control modules on them. A guy at work has a ZTR with a keypad instead of a key switch
#8 Little Irish Men OFFLINE
Little Irish Men
  • 825 Thanks
  • 470 posts
Posted January 05, 2016 - 03:22 PM
And DON"T FORGET  THE FIRE EXSTINGUISHER   some tractors can be replace, but you and your tools cant.  Now go have fun.
Patrick
  • MH81, Alc, boyscout862 and 2 others have said thanks
#9 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted January 05, 2016 - 06:34 PM
Very true, I know from experience.
Noel
#10 Little Irish Men OFFLINE
Little Irish Men
  • 825 Thanks
  • 470 posts
Posted January 05, 2016 - 07:40 PM
Noel
 I heard  or read something about that.
Patrick.
Edited by Little Irish Men, January 05, 2016 - 07:40 PM.
#11 MiCarl ONLINE
MiCarl
  • 2,016 Thanks
  • 1,049 posts
Posted January 06, 2016 - 04:36 PM
I tacked the shaft in place this afternoon.
You were all correct - the tractor still runs fine.
Thanks for your input.
  • limebuzz and Cvans have said thanks
#12 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 03, 2016 - 11:34 PM
Great! Now my two cent's worth...When I worked for Peterbilt Motors assembly plant in Nashville in weld dept. They sent me to Test dept to weld up a pusher axle after it was aligned. 6 1" passes all over head. Stick weld. I thought I did a fine job until our dept foreman told me later that I forgot to UN do the Cannon plug harnesses on the fire wall...I blew the "brain" on the truck....$3,000.
  • propane1 said thank you
#13 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted February 04, 2016 - 06:28 AM
Not your fault! Trucks shouldn't need "Brains". Only that of the driver!
  • BNK said thank you
#14 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 04, 2016 - 08:16 AM
LOL!!! ECU....back when I hired in the floorboards was still wood and the injector pump still had a linkage from the throttle. Sometimes I question the brains of some driver's tho...especially the one's that can't even speak a lick of English!
Also tagged with one or more of these keywords: welding
