Barn Find HP and Value
9 replies to this topic
#1 dennfen OFFLINE
dennfen
  • 3 Thanks
  • 2 posts
Posted January 04, 2016 - 09:50 PM
Picked this up last weekend. The large cast iron pully says Quick Mfging Springfield 2140. The engine is a Clinton. The serial number is 2070807 B and the model is B761AOG. The hp is wore off. I rubbed a lead pencil on it  to pickup some type of impression but came up with nothing.
I have more projects than i can handle and looking to find this a good home. Would appreciate any information and a fair value. You can't tell from pictures but there is a crack in the housing on the small pulley shaft.
Thanks
Dennis
  • Traill95, holdenboy1960 and chieffan have said thanks
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 04, 2016 - 10:49 PM
you found a Springfield, made during the 50's. They don't bring very much, I got my last 2 for $25 each.   The engine has about 1 1/2-2 hp.
  • HDWildBill and chieffan have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,341 Thanks
  • 4,960 posts
Posted January 05, 2016 - 12:08 AM
:welcometogttalk:  :wave:
Sad to admitt but I don't recall exactly what I paid for mine.   Think it was $17.50.  Decent shape and has always been shedded with virtually no weather checking on the tires.
I live less than 40 miles from the largest amish settlement west of the Mississippi River and that creates somewhat of a demand for walk behinds that other parts of the country might not see.
I do remember very vividly the first yank of the rope when the lil Clinton sprang to life like it was going to explode!  Thank goodness I kept my witts and yanked the plug wire quick saving the engine.  Once the air filter was removed I could see the problem.  The throttle butterfly had worked loose and it was sucking air/fuel at wide open even though the governor was telling it to idle down.  With 2 new screws reattaching the butterfly to the throttle shaft, the engine ran beautifully.  Those old Clintons were one heck of a good engine.
I can only assume the original two little brass screws went through the engine.  That why they are soft brass!
Edited by Gtractor, January 05, 2016 - 12:23 AM.
  • Lauber1, LilysDad, chieffan and 1 other said thanks
#4 chieffan ONLINE
  • 10,187 Thanks
  • 6,653 posts
Posted January 05, 2016 - 08:32 AM
Those little screws will digest fairly well as long as they don't get under a valve head.
  • Gtractor and 637Yeoman have said thanks
#5 Bud W ONLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted January 05, 2016 - 10:22 AM
You should peen those screws a little to keep them from vibrating loose.
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 05, 2016 - 05:44 PM
accurately they are from the factory, but   some times people take things apart the don't relies how it was put together the first time. Ive seen a lot of engines that swallowed tiny carb parts and lived to tell about it.
  • Gtractor said thank you
#7 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 05, 2016 - 05:56 PM
wow 17.50 is about bargain basement for anything running. I figure the tires are worth the $25 I spent on mine, and one set went to a Bolens. Theres two kinds of these tractors. One is red with yellow wheels and the other is green with yellow wheel . I used to know the model # for them. My Red one runs great and has one of the 700 series Clintons on it. that thing idles so slow you can hardly hear it run. I have several different attachments for it and the green one, which has a stuck 8R6 briggs on it. If the engine wasn't stuck and if it wasn't so hard to find a good 6-1 motor, I'd have it going again too. heres about the only picture I have of the RED model, and its evil brush cutter. Don't have one for the Green model.
  • DougT, Clifford Bridgford and 637Yeoman have said thanks
#8 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted January 09, 2016 - 07:04 PM
Her you can find  a good 6r6 or 8r6 pretty easily for aroudn 15-20 bucks.
I bought a planet jr Bp-1 With fenominal original paint and stickers with new tires and a good running 8r6 for 50$
  • Lauber1 said thank you
#9 dennfen OFFLINE
dennfen
  • 3 Thanks
  • 2 posts
Posted January 24, 2016 - 07:26 PM
Thanks all for the information. Any web sites where i could pick up parts?
#10 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted February 05, 2016 - 08:36 AM
:welcometogttalk:
