Changing belts on 18/6
7 replies to this topic
#1 sandhopper2 OFFLINE
sandhopper2
  • 6 Thanks
  • 32 posts
Posted January 04, 2016 - 11:35 AM
Thanks for all the manuals I have gotten from this site I think the belts I need are 100207 (5L370) for the FEL and 2692R for the drive, can someone confirm this for me . How do I replace the drive belt , I guess I need to build a ramp so I can get under this thing
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 11:37 AM
Does it have the two square head lights or is the older style. There is a mule box under the front on the kind with the two square lights that you need to loosen up
#3 sandhopper2 OFFLINE
sandhopper2
  • 6 Thanks
  • 32 posts
Posted January 04, 2016 - 12:02 PM
Looks like lights are round but grill is square
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 12:25 PM
Ok you have a 78 or 79, there is a belt gaurd around the drive pulley you have to take off. The loosen the tensioner on the right side. Push down the clutch and pull it off
#5 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted January 04, 2016 - 12:40 PM
Check out the link in my sig, it has some instructions about rear end removal and belts. You do not have to remove the rear like my thread is about, but you can see the pics of what you need to remove for the belt.
Your belt may require a different one than I used, I have a single Tecumseh engine.
  • Tecumseh power said thank you
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 01:09 PM
I think the onan twin takes an" and the single tecumseh takes an 81 don't hold me to it tho. It is is the manual on here you can check all 4 of mine are oh180s they take the 81
#7 JiminRI OFFLINE
JiminRI
  • 91 Thanks
  • 80 posts
Posted January 04, 2016 - 11:50 PM
The drive belt for the 18/6 model 917.25191 is listed as 2692R which is a 5/8" x 84" v-belt.
  • MH81 and sandhopper2 have said thanks
#8 sandhopper2 OFFLINE
sandhopper2
  • 6 Thanks
  • 32 posts
Posted January 05, 2016 - 02:48 PM
got both belts ordered , now when it quits raining I will got back to work on this tractor I have a lot of things I would like to do to make it mine
