how do the diesel pulling tractors wire a kill switch
22 replies to this topic
#16 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted January 11, 2016 - 01:47 PM
Since your not using a turbo you can still hookup the air guillotine to shut the air off. What kind of fuel pump are you using? You need to wire that to the kill switch as well.
#17 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted January 11, 2016 - 09:03 PM
The stock one that came on it no wires to it at all
#18 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted January 12, 2016 - 12:11 AM
Need to get a new pump then. I run a black series pump from jegs (120$) Runs about 20 pounds or so.
#19 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted January 12, 2016 - 12:18 AM
Ok
#20 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted January 12, 2016 - 12:19 AM
What gears to run in my trans we cant run pro tires
#21 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted January 12, 2016 - 12:52 PM
Everyone's setup is different so I will leave this trial and error up to you. Best of luck.
#22 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted January 12, 2016 - 10:21 PM
Thanks
#23 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted January 25, 2016 - 05:51 PM
Not sure but if I read the rules correctly I think you don't need to add a electric fuel pump but if you have one its needs  a kill switch on it. What I have done in the past with the same setup as 722 is used a electric solenoid to turn the fuel on and off on the injection pump. When you turn on your key this energize the solenoid turning on injector fuel (instead of a cable). Wire the kill switch in the circuit so if it gets pulled this will  kill power to solenoid killing engine.  Along with a air shut off to intake as Mike spoke of.
Edited by Saxist, January 25, 2016 - 05:59 PM.
